Still having trouble getting these packages downloaded
I'm not sure how to move past this one:
NOTE: Fetch svn://gforge.ti.com/svn/dmai/branches;module=BRANCH_BRIJESH_DMAI_DEV_2_xx;proto=https;user=anonymous;pswd=’’
Error validating server certificate for ‘https://gforge.ti.com:443’:
- The certificate is not issued by a trusted authority. Use the
fingerprint to validate the certificate manually!
Certificate information:
- Hostname: www.omapzoom.org
- Valid: from Wed, 15 Jul 2009 13:46:11 GMT until Thu, 15 Jul 2010 22:30:39 GMT
- Issuer: 07969287, http://certificates.godaddy.com/repository, GoDaddy.com, Inc., Scottsdale, Arizona, US
- Fingerprint: f9:d6:6c:5c:55:da:b2:29:2c:34:ab:9c:47:a8:56:6f:ed:4d:94:63
(R)eject, accept (t)emporarily or accept (p)ermanently? svn: OPTIONS of ‘https://gforge.ti.com/svn/dmai/branches/BRANCH_BRIJESH_DMAI_DEV_2_xx’: Server certificate verification failed: issuer is not trusted (https://gforge.ti.com)
NOTE: Task failed: Fetch failed: Fetch command export HOME=/home/gary; export PATH=/local/Angstrom_BeagleBoard/tmp/staging/i686-linux/usr/bin/beagleboard-angstrom-linux-gnueabi:/local/Angstrom_BeagleBoard/tmp/staging/i686-linux/usr/bin/armv7a-angstrom-linux-gnueabi:/local/Angstrom_BeagleBoard/tmp/staging/i686-linux/usr/sbin:/local/Angstrom_BeagleBoard/tmp/staging/i686-linux/usr/bin:/local/Angstrom_BeagleBoard/tmp/cross/armv7a//bin:/local/Angstrom_BeagleBoard/tmp/staging/i686-linux/sbin:/local/Angstrom_BeagleBoard/tmp/staging/i686-linux/bin:/home/gary/bitbake-1.8.18/bin:/local/Angstrom_BeagleBoard/bitbake/bin:/local/Angstrom_BeagleBoard/openembedded/bitbake/bin:/opt/amltd/bin:/usr/java/jdk1.6.0_10/bin:/home/gary/Android/android-sdk-linux_x86-1.1_r1/tools:/home/gary/bin:/usr/lib/qt-3.3/bin:/usr/kerberos/bin:/usr/lib/ccache:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin; /usr/bin/env svn co --username anonymous --password ‘’ -r 364 https://gforge.ti.com/svn/dmai/branches/BRANCH_BRIJESH_DMAI_DEV_2_xx@364 BRANCH_BRIJESH_DMAI_DEV_2_xx failed with signal 1, output:
