Would anyone be willing try out a new BeagleBoard image that I've created?
The next revision of the BeagleBoard image contains the following new
additions:- Kernel 3.0.3 with a lot of fixes and with LCD support
- gstreamer-ti and ti-dmai stack
- U-boot with fixes for hub power
- Fixes to U-boot environment variables for LCD
- systemd for very fast boot (thanks to Koen)
- gnome desktop
- pulseaudio
- alsa
- midori
- gedit
- gstreamer plugins
Other features included:
- Ability to be Auto-flashed to NAND by holding the userbutton when u-boot
loads- Ability to be rebuilt easily in SD card format
You can get this image in 2 simple ways:
1. Direct Download
2. Rebuild from scratch
You can rebuild the image by following instructions at:
http://www.angstrom-distribution.org/building-angstromWith the following differences:
1. Replace URLS in sources/layers.txt with ones similar to:
meta-angstrom,git://github.com/joelagnel/meta-angstrom.git,master,HEAD
meta-openembedded,git://github.com/joelagnel/meta-openembedded.git,master,HEAD
meta-texasinstruments,git://github.com/joelagnel/meta-texasinstruments.git,master,HEAD
openembedded-core,git://github.com/joelagnel/oe-core.git,HEAD
Personally, I like to follow the upstream work and just pull in
patches. If you tagged your trees per rX, that would be even easier.
What I did was:
$ cd ~/setup-scripts/sources/meta-angstrom
$ git remote add joel git://github.com/joelagnel/meta-angstrom.git
$ git remote update joel
$ git merge remotes/joel/master
I repeated that for meta-oe, meta-ti and oe-core.
Now, in the future, when I do a "./oebb.sh update", I'll be pulling in
the code from upstream, where I hope your patches for these releases
will land soon. When I get conflict errors, I'll be able to quickly
resolve them to take in the upstream versions. I will be able to
clean up my history with git rebase if desired at some point.
If you were going to recommend someone to use your fork by changing
layers.txt, I think you'd want to provide a similar fork for
setup-scripts and update layers.txt in it instead.
2. Build filesystem using Embedded by running the command:
bitbake beagleboard-validation-gnome-image
It might be a side effect of my approach (bringing in newer community
code), but I started getting errors with conf/bblayers.conf and
conf/site.conf being old. I was able to fix conf/bblayers.conf by
merging in Koen's latest and I was able to manually fix conf/site.conf
by adding:
SCONF_VERSION = "1"
