Beagleboard drive not poping up!
I have a beaglebone.
Plug the USB. LED turns on, but computer OS (fedora 16 KDE) doesn’t react to plugging/unplugging device.
Beaglebone is online. Cloud 9 is accessible.
How can I go back to having the bone work as a simple SD card from the host Os perspective?
Hey,
Try mounting the device from the disk utility. That might work.
In /var/log/messages, when I unplug and plug back in
Mar 29 11:55:58 cr1dev1 kernel: [ 4851.419402] usb 1-5: USB disconnect, device number 24
Mar 29 11:55:58 cr1dev1 kernel: [ 4851.419407] usb 1-5.1: USB disconnect, device number 25
Mar 29 11:55:58 cr1dev1 kernel: [ 4851.419614] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
Mar 29 11:55:58 cr1dev1 kernel: [ 4851.419630] ftdi_sio 1-5.1:1.0: device disconnected
Mar 29 11:55:58 cr1dev1 kernel: [ 4851.419748] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
Mar 29 11:55:58 cr1dev1 kernel: [ 4851.419760] ftdi_sio 1-5.1:1.1: device disconnected
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.157028] usb 1-5: new high speed USB device number 30 using ehci_hcd
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.271456] usb 1-5: New USB device found, idVendor=0424, idProduct=2412
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.271461] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.271737] hub 1-5:1.0: USB hub found
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.271825] hub 1-5:1.0: 2 ports detected
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.545224] usb 1-5.1: new high speed USB device number 31 using ehci_hcd
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.634582] usb 1-5.1: New USB device found, idVendor=0403, idProduct=6010
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.634587] usb 1-5.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.634590] usb 1-5.1: Product: BeagleBone/XDS100V2
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.634592] usb 1-5.1: Manufacturer: FTDI
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.634594] usb 1-5.1: SerialNumber: TIV7ZMKT
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.637019] ftdi_sio 1-5.1:1.0: FTDI USB Serial Device converter detected
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.637062] usb 1-5.1: Detected FT2232H
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.637064] usb 1-5.1: Number of endpoints 2
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.637066] usb 1-5.1: Endpoint 1 MaxPacketSize 512
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.637068] usb 1-5.1: Endpoint 2 MaxPacketSize 512
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.637069] usb 1-5.1: Setting MaxPacketSize 512
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.637409] usb 1-5.1: FTDI USB Serial Device converter now attached to ttyUSB0
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.639491] ftdi_sio 1-5.1:1.1: FTDI USB Serial Device converter detected
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.639528] usb 1-5.1: Detected FT2232H
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.639530] usb 1-5.1: Number of endpoints 2
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.639531] usb 1-5.1: Endpoint 1 MaxPacketSize 512
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.639533] usb 1-5.1: Endpoint 2 MaxPacketSize 512
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.639535] usb 1-5.1: Setting MaxPacketSize 512
Mar 29 11:56:01 cr1dev1 kernel: [ 4854.639749] usb 1-5.1: FTDI USB Serial Device converter now attached to ttyUSB1
Mar 29 11:56:01 cr1dev1 mtp-probe: checking bus 1, device 31: “/sys/devices/pci0000:00/0000:00:1d.7/usb1/1-5/1-5.1”
Mar 29 11:56:01 cr1dev1 mtp-probe: bus: 1, device: 31 was not an MTP device
Mar 29 11:56:04 cr1dev1 kernel: [ 4857.466094] usb 1-5.2: new high speed USB device number 32 using ehci_hcd
Mar 29 11:56:19 cr1dev1 kernel: [ 4872.539136] usb 1-5.2: device descriptor read/64, error -110
Mar 29 11:56:35 cr1dev1 kernel: [ 4887.713185] usb 1-5.2: device descriptor read/64, error -110
Mar 29 11:56:35 cr1dev1 kernel: [ 4887.887056] usb 1-5.2: new high speed USB device number 33 using ehci_hcd
Mar 29 11:56:38 cr1dev1 dhclient[1068]: DHCPREQUEST on em2 to 10.0.0.1 port 67
Mar 29 11:56:38 cr1dev1 NetworkManager[918]: DHCPREQUEST on em2 to 10.0.0.1 port 67
Mar 29 11:56:38 cr1dev1 dhclient[1068]: DHCPACK from 10.0.0.1
Mar 29 11:56:38 cr1dev1 NetworkManager[918]: DHCPACK from 10.0.0.1
Mar 29 11:56:38 cr1dev1 dhclient[1068]: bound to 10.0.4.2 – renewal in 78 seconds.
Mar 29 11:56:38 cr1dev1 NetworkManager[918]: bound to 10.0.4.2 – renewal in 78 seconds.
Mar 29 11:56:50 cr1dev1 kernel: [ 4902.960137] usb 1-5.2: device descriptor read/64, error -110
Mar 29 11:57:05 cr1dev1 kernel: [ 4918.134167] usb 1-5.2: device descriptor read/64, error -110
Mar 29 11:57:05 cr1dev1 kernel: [ 4918.308181] usb 1-5.2: new high speed USB device number 34 using ehci_hcd
Mar 29 11:57:16 cr1dev1 kernel: [ 4928.710019] usb 1-5.2: device not accepting address 34, error -110
Mar 29 11:57:16 cr1dev1 kernel: [ 4928.783071] usb 1-5.2: new high speed USB device number 35 using ehci_hcd
Mar 29 11:57:26 cr1dev1 kernel: [ 4939.185017] usb 1-5.2: device not accepting address 35, error -110
Mar 29 11:57:26 cr1dev1 kernel: [ 4939.185110] hub 1-5:1.0: unable to enumerate USB device on port 2
Are these last few entries (error + unable… ) expected?
