I assume you mean ‘are they working on the BeagleBoard’? They were, the last time I checked.
Yaman
Yaman
Hi Yaman,
Thanks for your reply. The examples are working fine on the
Beagleboard.
My concern here is that i am not sure that its utilizing the DSP or
not?
I am not copying the .lib file generated for the example to the
Beagleboard, do i need to copy?
Bhargav
If they give you some kind of output (assuming the output isn't some
error message stating that some problem arose while trying to control
the DSP or something like that), that should be fine - there isn't any
"DSP is in usage" LED on the board or anything like that but you have
the C6Run developers' word that it *is* utilizing the DSP if you
followed the C6RunLib/App build procedures
IIRC the examples are statically linked so there should be no need to
copy the .lib file.
Yaman
