Beagleboard ethernet gadget with Windows XP
Hi there, I am a newbie and facing some difficulty trying to set up the beagle as ethernet gadget (RNDIS).
My beagle is running Angstrom distro based on kernel 2.6.29. While connecting the usb-otg to
a windows XP machine, the kernel panic as shown in log below.
The windows inf file I used is also attached.
Could anone please advise? Thanks in advance.
kernel log:
can you try this with a kernel off of the head of linux-omap as well?
I downloaded the latest by doing:
$ git clone git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6.git linux-omap-2.6
and then using the omap3_beagle_defconfig to build the uImage off the head.
But the board get stuck while trying to boot the kernel.
Did I miss out anything ?
The console output:
Booting kernel from Legacy Image at 80300000 …
Image Name: Linux-2.6.32-rc5-06322-gf219b9d
Data Size: 2124304 Bytes = 2 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
** stuck **
  • Thomas
Apply this patch from omap-testing...
http://git.kernel.org/?p=linux/kernel/git/tmlind/linux-omap-2.6.git;a=commit;h=089bebfbdd92def910d69eafafe0719416b6441d
Thanks for replying. This patch is already in my code, and it does not help.
I recall someone mentioned in the mailing list this could be due to errors in omap3_beagle_defconfig that is missing config for tlw4030, regulator etc etc ?.
Can someone please send me a copy of omap3_beagle_defconfig that works with the lastest code ?
  • Thomas
Finally I get the board to boot by disablling the frambuffer support.
However, kernel still panic (same as before) when plugged into Windows XP as RNDIS gadget.
The kernel I used now is 2.6.32-rc5.
  • Thomas
