[beagleboard] Ethernet problem Rev A6
Software is good. But it cannot typically fix broken hardware. The fact that you can make it work using SW commands and it works, means the HW is working. An RMA is for HW issues and not SW issues. So. I see no value in requesting an RMA.
The earlier issue was fixed a while back and the A6 does not have that earlier issue.If it had, the the SW trick you tried would not have worked.
