I am needing to read 24 GPIO and write 24 GPIO 10,000 times per second.
Looking at clock rates of the processor(720MHz) and GPIO(100MHz) this seems
like it should be trivial but I haven't gotten close.I have tried using a python script that uses MMAP but only get about 29KHz
(for one pin, for 48 it would be 600Hz):
#This is a test program that blinks USR1 LED
#Using MMAP
#See: www.alexanderhiam.com/tutorials/beaglebone-io-using-python-mmap/
#To exit the program use "ctrl" + "c"from mmap import mmap
import time, structGPIO1_offset = 0x4804c000
GPIO1_size = 0x4804cfff-GPIO1_offset
GPIO_OE = 0x134
GPIO_SETDATAOUT = 0x194
GPIO_CLEARDATAOUT = 0x190
USR1 = 1<<22with open("/dev/mem", "r+b" ) as f:
mem = mmap(f.fileno(), GPIO1_size, offset=GPIO1_offset)with open("/sys/kernel/debug/omap_mux/lcd_data1", 'wb') as f:
f.write('27')reg = struct.unpack("<L", mem[GPIO_OE:GPIO_OE+4])[0]
mem[GPIO_OE:GPIO_OE+4] = struct.pack("<L", reg & ~USR1)try:
while(True):
mem[GPIO_SETDATAOUT:GPIO_SETDATAOUT+4] = struct.pack("<L", USR1)
#time.sleep(0.5)
mem[GPIO_CLEARDATAOUT:GPIO_CLEARDATAOUT+4] = struct.pack("<L", USR1)
#time.sleep(0.5)except KeyboardInterrupt:
mem.close()I've read things about using kernal modules but I am new to this and have
no idea how to use them.Any ideas on how I can make access the GPIO Faster?
I believe the easiest thing to do would be to use the PRUs. They run
at 200MHz and have direct access to the pins, though I don't think you
can access 48 of them from the PRUs without going through some tricks.
A kernel module does make sense in a lot of ways.
For the reading, you might consider using the GPMC if you are reading
the bits all at once. You could simply do a 32-bit read and capture 24
bits of valid data. You could even tie the DMA to it and use a timer
to trigger the reads.
It would be trivial if you weren't doing a ton of context switches.
Take a look at 'strace <your program>' to see how many times you are
making system calls that cause context switches (and realize that
those aren't the only things that would trigger a context switch).
Have you consider working without an OS, such as with StarterWare
(TI Sitara Starterware - BeagleBoard)?
