[beagleboard] flickering HDMI monitor with BBB
Turn the board over and press down on the connector. See if that affects the display.
I was not supposed to help. I was looking for it to be worse, checking for a bad connector. We have heard of a few cases where people get bad cables. It sure sounds like and intermittent connection issue.
how are you powering your BBB ?
OK. Just looking to see if there may be an issue with the connector. Sounds like there isn’t.
on an off chance i would try a 1 amp supply or one of the twin USB to mini connectors and give your
bone a bit more power
just a thought
That is a good thought!
