[beagleboard] GNU Radio benchmark_dotproduct?
I follow the last five steps of
http://www.opensdr.com/node/17
with my custom options to compile and install
the GNU Radio 3.2.2 with Ubuntu 9.10 on SBC8100 (DevKit8000-like).
# export LD_LIBRARY_PATH=/usr/local/lib
# ./bootstrap
# ./configure --with-boost=/usr/local --disable-usrp2 --with-fusb-
tech=libusb1 CFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon -
mfloat-abi=softfp" CXXFLAGS="-march=armv7-a -mtune=cortex-a8 -
mfpu=neon -mfloat-abi=softfp"
# make
# make check
# sudo make install
when I try the lastest step "# Run benchmark_dotproduct, make code
faster."
I could not find out the "benchmark_dotproduct"!
Does anyone know this?
p.s.
I had tested ./gnuradio-3.2.2/gnuradio-examples/python/usrp/
usrp_benchmark_usb.py
and ./gnuradio-3.2.2/usrp/host/apps/test_usrp_standard_tx
and ./gnuradio-3.2.2/usrp/host/apps/test_usrp_standard_rx
They are ok!
# ./bootstrap
# make
# make check
# sudo make install
faster."
Look in
./gnuradio-core/src/tests/
Philip
2010/4/26 Philip Balister <philip.balister@gmail.com>
./bootstrap
tech=libusb1 CFLAGS=“-march=armv7-a -mtune=cortex-a8 -mfpu=neon -
mfloat-abi=softfp” CXXFLAGS=“-march=armv7-a -mtune=cortex-a8 -
mfpu=neon -mfloat-abi=softfp”
make
make check
sudo make install
when I try the lastest step “# Run benchmark_dotproduct, make code
faster.”
I could not find out the “benchmark_dotproduct”!
Look in
Philip
Ok, I got it! Thanks a lot.
BTW, I re-configure & make with
–with-boost=/usr/local CFLAGS=“-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp” CXXFLAGS=“-march=armv7-a -mtune=cortex-a8 -mfpu=neon -mfloat-abi=softfp”
(drop the “–disable-usrp2 --with-fusb-tech=libusb1”), unless I got errors.
It’s work, but very slow.
./usrp/host/apps/test_usrp_standard_rx
xfered 1.34e+08 bytes in 4.88 seconds. 2.751e+07 bytes/sec. cpu time = 4.461
./usrp/host/apps/test_usrp_standard_tx
xfered 3.2e+07 bytes in 1.43 seconds. 2.234e+07 bytes/sec. cpu time = 1.36
I think the cpu time is too long.
./gnuradio-examples/python/usrp/usrp_benchmark_usb.py
> # ./bootstrap
> # make
> # make check
> # sudo make install
> faster."
Look in
Philip
--with-boost=/usr/local CFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon
-mfloat-abi=softfp" CXXFLAGS="-march=armv7-a -mtune=cortex-a8 -mfpu=neon
-mfloat-abi=softfp"
(drop the "--disable-usrp2 --with-fusb-tech=libusb1"), unless I got errors.
It's work, but very slow.
# ./usrp/host/apps/test_usrp_standard_rx
4.461
# ./usrp/host/apps/test_usrp_standard_tx
I'm not sure how good the usb drivers are for high speed transfers. I
haven't looked into the usb drivers very much.
Philip
2010/4/27 Philip Balister <philip.balister@gmail.com>
I’m not sure how good the usb drivers are for high speed transfers. I
haven’t looked into the usb drivers very much.
Philip
Ok, fine.
I think I’m better to back to x86 desktop. :-[
Philip
Ok, fine.
I think I'm better to back to x86 desktop. :-[
GNU Radio on OMAP3 is a work in progress. Thanks for testing the build process!
Good luck with GNU Radio on the x86.
Philip
Tested with new ubuntu lucid rootfs, compared with last result:
Ubuntu 9.10 (Karmic): 1.34e+08 bytes in 4.88 seconds. 2.751e+07 bytes/sec. cpu time = 4.461
Ubuntu 10.04 (Lucid): 1.34e+08 bytes in 4.53 seconds. 2.96e+07 bytes/sec. cpu time = 4.156
(Desktop PC: 3.2e+07 bytes/sec, cpu time = 0.032)
Ubuntu 9.10 (Karmic): 3.2e+07 bytes in 1.43 seconds. 2.234e+07 bytes/sec. cpu time = 1.36
Ubuntu 10.04 (Lucid): 3.2e+07 bytes in 1 seconds. 3.191e+07 bytes/sec. cpu time = 0.633
(Desktop PC: 3.2e+07 bytes/sec, cpu time = 0.024)
Ubuntu 9.10 (Karmic): Max USB/USRP throughput = 4MB/sec
Ubuntu 10.04 (Lucid): Max USB/USRP throughput = 8MB/sec
(Desktop PC: 32MB/sec, i.e. all pass)
sudo ./gnuradio-examples/python/digital/benchmark_tx.py
still has “uU”
You can see some improvement, but not much.
cpu time = 4.461
cpu time = 4.156
cpu time = 1.36
cpu time = 0.633
# ./gnuradio-examples/python/usrp/usrp_benchmark_usb.py
# sudo ./gnuradio-examples/python/digital/benchmark_tx.py
still has "uU"
What changes between the two versions that might impact gnuradio?
Philip
only two things,
1.) update(replace) rootfs from ubuntu karmic to lucid (a new one),
2.) added “-Os” to CFLAGS/CXXFLAGS, when ./configure
2010/5/11 Philip Balister <philip.balister@gmail.com>
