Pramod,
Thanks for the patch, see my comments below.
--- a/recipes/opencv/opencv-dsp-acceleration_svn.bb
+++ b/recipes/opencv/opencv-dsp-acceleration_svn.bb
do_configure() {
+ #DSPLIB uses '\' instead of '/' as directory seperator. Correct it
+ sed -i -e 's:\\:\/:g' ${DSPLIB_PATH}/dsplib64plus.h
Hi Koen,
Thanks for the comments.
If the directory seperator was aleady fixed in dsplib recipe, it should not be needed. I had trouble bitbaking until I fixed it. I will see that again.
I will send you the new patch with those comments addressed.
Pramod
Hi Koen,
I made the necessary changes in the Makefile as suggested. Please find the patch. I have bumped the revsion number in this patch.
Pramod Poudel
0001-opencv-dsp-acceleration-Revision-changed-to-128.patch (1.38 KB)
Hi Koen,
Close, but not quite there
Signed-off-by: Pramod Poudel <ppoudel@jars-desktop.(none)>
Those aren't valid address, you probably need to do:
git config --global user.name "Your Name"
git config --global user.email "your@email.com"
${OE_BASE}/build/tmp-angstrom_2008_1/sysroots/beagleboard-angstrom-linux-gnueabi is a bit to specific, please change that to:
${STAGING_DIR}/${MULTIMACH_TARGET_SYS}${installdir}/imglib_v201 that way it will work for other machines and other build layouts.
regards,
Koen
Hi Koen,
Please find the attached file. Hope I have’t done something wrong with it .
Pramod Poudel
0001-opencv-dsp-acceleration-Revision-changed-to-128.patch (1.44 KB)
