Hi all,
I wrote an entry about device vs hub emulation on the blog
(http://beagleboard-usbsniffer.blogspot.com/2010/05/device-vs-hub-emulation
.html). I reproduced the content below, it would be great if someone could
check if my understanding of USB hub is correct.
Then I'll start researching/writing something about how I think device
emulation would work.
wrt the blog text: not sure which port you mean with MUSB port. I
would expect the device-to-be-sniffed to be connected to the regular
(EHCI) port and the OTG port to the host.
Yes. By MUSB I mean the slave (gadget, OTG) controller (the EHCI controller does not seem to be part of the MUSB IP, from what I see in the datasheet).
The OTG port will definitely be able to deal with address 0 as it can
be used to act as a slave device.
My concern is that the OTG port may only be able to deal with _one_ address at a time. It will answer to address 0 after a reset, but as soon as it is assigned an address by the host, it will answer to that address, and not any other.
Some more remarks:
- the device to be emulated can only be a HS device as other speeds
are not supported by the EHCI port.
Sure, for LS/FS, we need a hub (a real physical USB hub ,-)), I'm aware of that.
- you might want to consider the case where a physical device actually
represents multiple devices. E.g. a simple voip handset might present
itself as an audio-in, audio-out, input (kbd) and output (lcd) device.
As long as all these devices answer to the same USB address, it should not be a problem.
Ideally a sniffer should be able to sniff all traffic (so also if
there is a physical hub downstream).
That, I don't think would be feasible. If there is a hub downstream, there will be multiple addresses.
What we could do, if there is a hub, is to "pick" one device, and forward the traffic to it (that would be useful for the LS/FS case, where a hub is needed).
Having said that, I think you should probably focus at a single device
first, but keep this in mind, so you do not close doors or make
decisions that disallow that (or if you have to then at least it was a
conscious decision).
Yes of course. That's why I prefered a hub solution in the first place (more flexibility). But if that can't be done...
And, as mentioned before, synchronous transfers may cause additional
pain (and be a reason to do most, if not all, in the kernel). Note
that synchronous does not mean delay-less (a hub will also cause some
delay), but it may well mean that the latency (if any) is constant.
Sure.
Wrt the acquisition and display of the data: I would suggest
investigating if it is possible to use a wireshark plugin.
There is a wireshark plugin for USB traffic dumped from usbmon (USB). If we keep the usbmon interface, that comes for free.
Then again, probably the initial focus should be to have the data
passing through the beagle (probably starting with a single device).
Maybe that is a good mid-term goal.
Indeed. I plan to start with simple devices, with limited number of endpoints, and slowly start to support different endpoint types (control/bulk, then interrupt, and finally isochronous).
Thanks.
Best regards,
Nicolas
