has anyone got HD 720p AV work properly with no DSP?
Or with DSP ?
I never reach 720p x 30fps... I tried lot of options but without sucess.
best regards,
- Roberto
no, it does not work without the dsp
you can have some (mpeg4) 720p playing with no sound on arm only.
Vladimir,
Do you have some driver option to use DSP and run @ 720p 30fps ?
best regards,
- Roberto
Roberto Alcântara wrote:
Vladimir,
today, playing H264 HP 720p at 24/25fps is the very limit, this is
using a commercial codec that fully loads the arm and the dsp and actually running the omap3 at 800mhz.
so there is no simple "driver option" to make that possible....
