[beagleboard] HDMI Input
It really depends on what resolution you need for HDMI. You would need to provide an HDMI decoder to send the raw video to the camera input. The camera input will not support 24 bit HDMI data, so it would need to be scaled down with external logic. It would require designing some HW, Then you have the protection issue to deal with on the content. Getting an HDMI decoder would require some licensing and you would have to convince them that you are a manufacturer of such devices.
I think you have the gist of it. As to Mplayer capturing 720p, I am not sure on that. Maybe others have had some experience in that area.
Mplayer is a playback app, not a capture app
I don't follow your discussion: HDMI is a set differential pairs,
camera is parallel. What to what do you want to connect? First you
need to deserialize HDMI to raw LCD and then connect it to the camera
interface. I'm not sure it can swallow 720p30
