Without any more information than that, It's hard to say. Off hand, I
notice that main.cpp is C++. Do you have the prototype for
yuv422torgb888() declared as extern "C" in main.cpp?
After type the command ndk-build, the console get the error message:
"Compile++ arm : v2d <= global.cpp
"Compile++ arm : v2d <= haarDetector.cpp
"Compile++ arm : v2d <= haarTab.cpp
"Compile++ arm : v2d <= initPara.cpp
"Compile++ arm : v2d <= main.cpp
"Compile++ arm : v2d <= resize.cpp
"Compile++ arm : v2d <= track_haar.cpp
"Compile++ arm : v2d <= track_rgb.cpp
"Compile arm : v2d <= yuv422torgb888.s
SharedLibrary : libv2d.so
E:/DSP/2d_lib//obj/local/armeabi/objs/v2d/main.o: In function
`GetOneFrame(unsigned char*, unsigned char*)':
E:/DSP/2d_lib//jni/main.cpp:239: undefined reference to
`yuv422torgb888(unsigned char*, unsigned char*, void*, int)'
collect2: ld returned 1 exit status
make: *** [E:/DSP/2d_lib//obj/local/armeabi/libv2d.so] Error 1
How to fix this problem ?
Hi Eric,
No, he does not. If he did, the linker error message could not show the
full function signature.
