[beagleboard] How to configure networking?
I've just installed Ubuntu with --use-default-user option.
Can't figure out how to enable networking over Ethernet-USB adapter.
ubuntu@omap:~$ lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 9710:7830 MosChip Semiconductor MCS7830
Ethernet
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port
HUB
ubuntu@omap:~$ ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Which kernel? (uname -a) if it's mine, that one is enabled..
force networking with:
sudo ifconfig -a
eth0 should show up..
then
sudo dhclient eth0
PS.. Yuck... if this is put in the field, have a hot backup of a
different chipset... I've had 4 of these chipset's fail in the last
year (averaged 3-6 months)..
