[beagleboard] How to copy RFS to NAND?
I try to boot from NAND with u-boot, uImage and RFS put to NAND.
But when I put JFSS2 downloaded to NAND, it can’t be recognized. When I power on, it says
vfs: Cannot open root device “mtdblock4” or unknown-block(31,4)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31, 4)
I copy JFFS2 file system to NAND with u-boot not kernel. I tried mtd-utils but I failed.
Does anyone know any way to put a RFS to NAND and boot from NAND? I don’t want SD card inserted to beagleboard.
Thank you.
Evan
Hi Evan,
But when I put JFSS2 downloaded to NAND, it can't be recognized. When I
power on, it says
vfs: Cannot open root device "mtdblock4" or unknown-block(31,4)
but I failed.
Does anyone know any way to put a RFS to NAND and boot from NAND? I don't
Have you had a look at: BeagleBoardNAND - eLinux.org?
Best regards – Good luck
  Søren
Hi Soren,
Thank you for your suggestion
Yes. I just followed procedures there.
I wrote RFS with u-boot. But system can’t load RFS.
I want to try writing RFS with kernel. But it needs MTD Utils. I can’t compile and get MTD Utils in lernel. because no make in kernel So I can’t writing RFS with kernel.
I think the actual Android device will boot from NAND not SD card because SD card slot is for customer to access.
Does everyone here boot from SD card? How can I do?
Evan
Hi!
I’ve compiled mtd utils to work with flash. Try and tell us if they work
http://www.mentorel.com/downloads/flash-utils.tgz
2010/5/19 Evan G <evan.g374@gmail.com>
