Hi all,
What would be best (=most reliable) way to control i/o lines with Beagle in Ubuntu?
Does anybody have examples to read and write i/o pin at external connector on Beagle?
Thank you in advance.
-Petri-
Hi all,
-Petri-
If you are referring to the omap's gpio pins, then you should take a
look at Documentation/gpio.txt in the linux kernel tree. The kernel
exposes gpio pins in /sys/class/gpio (iirc).
- Ben
Here is a good link for GPIOs:
http://blog.makezine.com/archive/2009/02/blinking_leds_with_the_beagle_board.html
If you want to edit the files in /sys/class/gpio/ as a normal user you will need to chmod export, unexport, the gpioX/value, and possibly the gpioX/direction files.
Hope this helps.
– Andruk
