[beagleboard] installing PyBBIO library to beaglebone
hi friends,
I have a beaglebone Rev.A6 as a newer.
I want to use PyBBIO library in it but ı could not install from
https://github.com/alexanderhiam/PyBBIO .
What's your opinion and advise to me ?
What challenge did you have? Did you attempt to use 'git clone'?
yes we used ‘git clone’ friend
What challenge are you having? Please provide logs.
________________________________________
From: beagleboard@googlegroups.com [beagleboard@googlegroups.com] on behalf of emin.vilgenoglu@gmail.com [emin.vilgenoglu@gmail.com]
Sent: Monday, February 11, 2013 4:07 AM
To: beagleboard@googlegroups.com
Cc: jason.kridner@hangerhead.com
Subject: Re: [beagleboard] installing PyBBIO library to beaglebone
yes we used 'git clone' friend
9 Şubat 2013 Cumartesi 14:26:44 UTC+2 tarihinde Jason Kridner yazdı:
hi friends,
The git clone is probably failing due to the certificate check. Either installs certs on the BeableBone or disable the SSL check:
$ env GIT_SSL_NO_VERIFY=true git clone https://site.com/something.git
