I have bought an inexpensive JTAG XDS510-UB2.0 clone from
www.00ic.com (TI's original part is far to expensive for me).
Now I want to "debug" mainly the DSP of the BB but up to now
I have not much luck!
I have created a new board based on the template of my cheap JTAG
emulator and have duplicated all settings from the original TI OMAP3530
XDS510 board.
After removing the GEL file from the ICEPICK_C component I was able to
connect to it
But no luck for the C6400PLUS (GEL also removed)
Error connecting to the target:
Error 0x80000240/-1146
Fatal Error during: Initialization, OCS,
Invalid data was scanned by the emulation controller.
Verify the board setup to make sure the scan chain is properly defined.
If the setup is correct, then RESET EMULATOR. This will disconnect each
target from the emulator. The targets should then be power cycled
or hard reset followed by an emureset and reconnect to each target.
I/O Port = 240
Board Name: Beagleboard
Cpu Name: C6400PLUS_0
or the CS_DAP_PC component (GEL also removed)
Error 0x80000240/-5005
Unknown Error
I/O Port = 240
Cpu Name: CS_DAP_PC_0
Has anybody out there such an cheap emulator successfully running with an BB?
Could the errors be due to running Windows XP and CCS within a virtual machine from a linux host?
Could this be due to the BB hardware revision C4 (720 MHz)?
Any help would be great!
Thanks in advance!
Regards
Martin
