[beagleboard] Kernel boot stops
I followed to get the linux2.6.29, and i built uImage and running on our target board. here is the log
U-Boot 1.3.3 (Jul 1 2009 - 07:20:35)
OMAP3530-GP rev 2, CPU-OPP2 L3-165MHz
OMAP3 eReader Board + LPDDR/NAND
DRAM: 128 MB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Audio Tone on Speakers … complete
Hit any key to stop autoboot: 3  2  1  0
reading uImage
2762948 bytes read
## Booting kernel from Legacy Image at 80300000 …
Image Name: Linux-2.6.29-omap1
Data Size: 2762884 Bytes = 2.6 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
[ 0.000000] Linux version 2.6.29-omap1 (root@INETFI-LINUX-MC4) (gcc version 4.2.1 (CodeSourcery Sourcery G++ Lite 2007q3-51)) #1 Wed Jul 1 17:16:05 IST 2009
[ 0.000000] CPU: ARMv7 Processor [411fc082] revision 2 (ARMv7), cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 ES2.1
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8 mem=128M noinitrd rw root=/dev/mmcblk0p2 rootdelay=5 rootfstype=ext3
[ 0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] PID hash table entries: 512 (order: 9, 2048 bytes)
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 123888KB available (5124K code, 559K data, 188K init)
[ 0.000000] Calibrating delay loop… 485.26 BogoMIPS (lpj=1896448)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] net_namespace: 1036 bytes
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 21.816284] OMAP DMA hardware revision 4.0
[ 21.855346] bio: create slab at 0
[ 21.865447] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 21.869964] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 21.869995] twl4030: power (irq 373) chaining IRQs 376…383
[ 21.870513] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 21.873657] regulator: VMMC1: 1850 ↔ 3150 mV normal standby
[ 21.874511] regulator: VDAC: 1800 mV normal standby
[ 21.875335] regulator: VUSB1V5: 1500 ↔ 0 mV normal standby
[ 21.876129] regulator: VUSB1V8: 1800 ↔ 0 mV normal standby
[ 21.876953] regulator: VUSB3V1: 3100 ↔ 0 mV normal standby
[ 21.877777] regulator: VPLL2: 1800 mV normal standby
[ 21.878601] regulator: VSIM: 1800 ↔ 3000 mV normal standby
[ 21.888122] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 21.890075] SCSI subsystem initialized
[ 21.891174] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 21.892639] usbcore: registered new interface driver usbfs
[ 21.893188] usbcore: registered new interface driver hub
[ 21.893585] usbcore: registered new device driver usb
[ 21.896667] Bluetooth: Core ver 2.14
[ 21.897155] NET: Registered protocol family 31
[ 21.897186] Bluetooth: HCI device and connection manager initialized
[ 21.897186] Bluetooth: HCI socket layer initialized
[ 21.897888] cfg80211: Using static regulatory domain info
[ 21.897918] cfg80211: Regulatory domain: US
[ 21.897918] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 21.897949] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 21.897979] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 21.897979] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 21.898010] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 21.898010] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 21.898040] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 21.898071] cfg80211: Calling CRDA for country: US
[ 21.901336] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 21.902069] musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
[ 21.903198] NET: Registered protocol family 2
[ 21.903656] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 21.904235] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 21.904388] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 21.904479] TCP: Hash tables configured (established 4096 bind 4096)
[ 21.904510] TCP reno registered
[ 21.904785] NET: Registered protocol family 1
[ 21.908843] VFS: Disk quotas dquot_6.5.2
[ 21.908935] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 21.909423] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 21.910125] JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 21.910919] msgmni has been set to 242
[ 21.915710] alg: No test for stdrng (krng)
[ 21.915832] io scheduler noop registered
[ 21.915832] io scheduler anticipatory registered
[ 21.915863] io scheduler deadline registered
[ 21.916015] io scheduler cfq registered (default)
[ 21.938629] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 21.960632] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 21.960662] console [ttyS0] enabled
[ 22.448303] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 22.476074] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 22.494750] brd: module loaded
[ 22.503326] loop: module loaded
[ 22.506896] usbcore: registered new interface driver catc
[ 22.512329] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 22.519073] usbcore: registered new interface driver kaweth
[ 22.524749] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 22.532592] usbcore: registered new interface driver pegasus
[ 22.538360] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 22.545562] usbcore: registered new interface driver rtl8150
[ 22.551513] usbcore: registered new interface driver asix
[ 22.557250] usbcore: registered new interface driver cdc_ether
[ 22.563446] usbcore: registered new interface driver dm9601
[ 22.569366] usbcore: registered new interface driver smsc95xx
[ 22.575469] usbcore: registered new interface driver gl620a
[ 22.581329] usbcore: registered new interface driver net1080
[ 22.587341] usbcore: registered new interface driver plusb
[ 22.593170] usbcore: registered new interface driver rndis_host
[ 22.599426] usbcore: registered new interface driver cdc_subset
[ 22.605712] Broadcom 43xx driver loaded [ Features: L, Firmware-ID: FW13 ]
[ 22.613067] usbcore: registered new interface driver zd1211rw
[ 22.619171] usbcore: registered new interface driver rtl8187
[ 22.625244] usbcore: registered new interface driver rndis_wlan
[ 22.631500] usbcore: registered new interface driver zd1201
[ 22.637420] usbcore: registered new interface driver usb8xxx
[ 22.643493] usbcore: registered new interface driver rt2500usb
[ 22.649688] usbcore: registered new interface driver rt73usb
[ 22.655700] usbcore: registered new interface driver p54usb
[ 22.661346] i2c /dev entries driver
[ 22.666381] Driver ‘sd’ needs updating - please use bus_type methods
[ 22.673095] Driver ‘sr’ needs updating - please use bus_type methods
[ 22.680541] omap2-nand driver initializing
[ 22.685028] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
[ 22.694061] cmdlinepart partition parsing not available
[ 22.699340] Creating 5 MTD partitions on “omap2-nand”:
[ 22.704528] 0x000000000000-0x000000080000 : “X-Loader”
[ 22.711547] 0x000000080000-0x000000260000 : “U-Boot”
[ 22.718505] 0x000000260000-0x000000280000 : “U-Boot Env”
[ 22.725128] 0x000000280000-0x000000680000 : “Kernel”
[ 22.732940] 0x000000680000-0x000010000000 : “File System”
[ 22.843414] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 22.850463] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 22.857147] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 22.865051] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 22.880065] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 22.886657] usb usb1: configuration #1 chosen from 1 choice
[ 22.892761] hub 1-0:1.0: USB hub found
[ 22.896697] hub 1-0:1.0: 3 ports detected
[ 22.902832] Initializing USB Mass Storage driver…
[ 22.908203] usbcore: registered new interface driver usb-storage
[ 22.914306] USB Mass Storage support registered.
[ 22.919036] g_cdc gadget: using random self ethernet address
[ 22.924743] g_cdc gadget: using random host ethernet address
[ 22.931304] usb0: MAC 82:38:50:c5:f7:0c
[ 22.935211] usb0: HOST MAC a2:67:bd:6f:13:ba
[ 22.940032] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 22.947692] g_cdc gadget: g_cdc ready
[ 22.951416] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 22.957366] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
[ 22.965423] usb usb2: configuration #1 chosen from 1 choice
[ 22.971557] hub 2-0:1.0: USB hub found
[ 22.975463] hub 2-0:1.0: 1 port detected
[ 22.981384] mice: PS/2 mouse device common for all mice
[ 22.987396] input: gpio-keys as /class/input/input0
[ 22.994750] input: twl4030_pwrbutton as /class/input/input1
[ 23.001861] twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
[ 23.009216] twl4030_rtc twl4030_rtc: Power up reset detected.
[ 23.015441] twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
[ 23.023315] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 23.029754] Bluetooth: HCI UART driver ver 2.2
[ 23.034240] Bluetooth: HCI H4 protocol initialized
[ 23.039093] Bluetooth: HCI BCSP protocol initialized
[ 23.044128] Bluetooth: HCILL protocol initialized
[ 23.048858] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 23.055328] usbcore: registered new interface driver bcm203x
[ 23.061126] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 23.067352] usbcore: registered new interface driver bpa10x
[ 23.073089] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 23.078674] usbcore: registered new interface driver bfusb
[ 23.084259] Bluetooth: Generic Bluetooth USB driver ver 0.4
[ 23.090240] usbcore: registered new interface driver btusb
[ 23.095855] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 23.103057] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
[ 23.217224] Registered led device: beagleboard::usr0
[ 23.222717] Registered led device: beagleboard::usr1
[ 23.228576] Registered led device: beagleboard::pmu_stat
[ 23.240600] usbcore: registered new interface driver usbhid
[ 23.246215] usbhid: v2.6:USB HID core driver
[ 23.251708] Advanced Linux Sound Architecture Driver Version 1.0.18a.
[ 23.259124] usbcore: registered new interface driver snd-usb-audio
[ 23.265808] ALSA device list:
[ 23.268798] No soundcards found.
[ 23.273010] oprofile: using arm/armv7
[ 23.276947] TCP cubic registered
[ 23.280273] NET: Registered protocol family 17
[ 23.284790] NET: Registered protocol family 15
[ 23.289337] Bluetooth: L2CAP ver 2.11
[ 23.293029] Bluetooth: L2CAP socket layer initialized
[ 23.298156] Bluetooth: SCO (Voice Link) ver 0.6
[ 23.302734] Bluetooth: SCO socket layer initialized
[ 23.307800] Bluetooth: RFCOMM socket layer initialized
[ 23.313049] Bluetooth: RFCOMM TTY layer initialized
[ 23.317993] Bluetooth: RFCOMM ver 1.10
[ 23.321777] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 23.327148] Bluetooth: BNEP filters: protocol multicast
[ 23.332397] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 23.346801] RPC: Registered udp transport module.
[ 23.351623] RPC: Registered tcp transport module.
[ 23.356414] lib80211: common routines for IEEE802.11 drivers
[ 23.362213] ThumbEE CPU extension supported.
[ 23.366516] Power Management for TI OMAP3.
[ 23.371185] SmartReflex driver initialized
[ 23.382629] Disabling unused clock “sr2_fck”
[ 23.386962] Disabling unused clock “sr1_fck”
[ 23.391326] Disabling unused clock “mcbsp_fck”
[ 23.395843] Disabling unused clock “mcbsp_fck”
[ 23.400299] Disabling unused clock “mcbsp_fck”
[ 23.404846] Disabling unused clock “mcbsp_ick”
[ 23.409301] Disabling unused clock “mcbsp_ick”
[ 23.413818] Disabling unused clock “mcbsp_ick”
[ 23.418273] Disabling unused clock “gpt2_ick”
[ 23.422698] Disabling unused clock “gpt3_ick”
[ 23.427093] Disabling unused clock “gpt4_ick”
[ 23.431488] Disabling unused clock “gpt5_ick”
[ 23.435882] Disabling unused clock “gpt6_ick”
[ 23.440277] Disabling unused clock “gpt7_ick”
[ 23.444702] Disabling unused clock “gpt8_ick”
[ 23.449096] Disabling unused clock “gpt9_ick”
[ 23.453491] Disabling unused clock “wdt3_ick”
[ 23.457885] Disabling unused clock “wdt3_fck”
[ 23.462310] Disabling unused clock “gpio2_dbck”
[ 23.466888] Disabling unused clock “gpio3_dbck”
[ 23.471435] Disabling unused clock “gpio4_dbck”
[ 23.476043] Disabling unused clock “gpio5_dbck”
[ 23.480590] Disabling unused clock “gpio6_dbck”
[ 23.485168] Disabling unused clock “gpt9_fck”
[ 23.489593] Disabling unused clock “gpt8_fck”
[ 23.493988] Disabling unused clock “gpt7_fck”
[ 23.498382] Disabling unused clock “gpt6_fck”
[ 23.502777] Disabling unused clock “gpt5_fck”
[ 23.507171] Disabling unused clock “gpt4_fck”
[ 23.511566] Disabling unused clock “gpt3_fck”
[ 23.515991] Disabling unused clock “gpt2_fck”
[ 23.520355] Disabling unused clock “gpt1_ick”
[ 23.524780] Disabling unused clock “wdt1_ick”
[ 23.529174] Disabling unused clock “wdt2_ick”
[ 23.533569] Disabling unused clock “wdt2_fck”
[ 23.537994] Disabling unused clock “gpio1_dbck”
[ 23.542541] Disabling unused clock “gpt1_fck”
[ 23.546966] Disabling unused clock “cam_ick”
[ 23.551300] Disabling unused clock “cam_mclk”
[ 23.555725] Disabling unused clock “dss_ick”
[ 23.560058] Disabling unused clock “dss_96m_fck”
[ 23.564727] Disabling unused clock “dss1_alwon_fck”
[ 23.569671] Disabling unused clock “des1_ick”
[ 23.574066] Disabling unused clock “sha11_ick”
[ 23.578552] Disabling unused clock “rng_ick”
[ 23.582855] Disabling unused clock “aes1_ick”
[ 23.587249] Disabling unused clock “ssi_ick”
[ 23.591583] Disabling unused clock “mailboxes_ick”
[ 23.596405] Disabling unused clock “mcbsp_ick”
[ 23.600921] Disabling unused clock “mcbsp_ick”
[ 23.605377] Disabling unused clock “gpt10_ick”
[ 23.609863] Disabling unused clock “gpt11_ick”
[ 23.614379] Disabling unused clock “i2c_ick”
[ 23.618682] Disabling unused clock “mcspi_ick”
[ 23.623168] Disabling unused clock “mcspi_ick”
[ 23.627655] Disabling unused clock “mcspi_ick”
[ 23.632141] Disabling unused clock “mcspi_ick”
[ 23.636627] Disabling unused clock “hdq_ick”
[ 23.640930] Disabling unused clock “mspro_ick”
[ 23.645416] Disabling unused clock “des2_ick”
[ 23.649841] Disabling unused clock “sha12_ick”
[ 23.654327] Disabling unused clock “aes2_ick”
[ 23.658721] Disabling unused clock “icr_ick”
[ 23.663024] Disabling unused clock “pka_ick”
[ 23.667327] Disabling unused clock “ssi_ssr_fck”
[ 23.671997] Disabling unused clock “hdq_fck”
[ 23.676300] Disabling unused clock “mcspi_fck”
[ 23.680786] Disabling unused clock “mcspi_fck”
[ 23.685302] Disabling unused clock “mcspi_fck”
[ 23.689758] Disabling unused clock “mcspi_fck”
[ 23.694274] Disabling unused clock “mcbsp_fck”
[ 23.698730] Disabling unused clock “mcbsp_fck”
[ 23.703247] Disabling unused clock “i2c_fck”
[ 23.707550] Disabling unused clock “mspro_fck”
[ 23.712036] Disabling unused clock “gpt11_fck”
[ 23.716552] Disabling unused clock “gpt10_fck”
[ 23.721008] Disabling unused clock “dpll4_m6x2_ck”
[ 23.725860] Disabling unused clock “dpll4_m3x2_ck”
[ 23.730682] Disabling unused clock “dpll3_m3x2_ck”
[ 23.735534] Disabling unused clock “sys_clkout1”
[ 23.740234] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 23.754272] registered taskstats version 1
[ 23.760314] twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 23.769256] Waiting 5sec before mounting root device…
[ 24.122344] mmc0: new high speed SD card at address 0007
[ 24.128387] mmcblk0: mmc0:0007 SD02G 1.86 GiB
[ 24.133178] mmcblk0: p1 p2
[ 33.010681] kjournald starting. Commit interval 5 seconds
[ 33.016296] EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
[ 33.239959] EXT3 FS on mmcblk0p2, internal journal
[ 33.244781] EXT3-fs: recovery complete.
[ 33.467163] EXT3-fs: mounted filesystem with ordered data mode.
[ 33.473175] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 33.479431] Freeing init memory: 188K
INIT: version 2.86 booting
modprobe: FATAL: Could not load /lib/modules/2.6.29-omap1/modules.dep: No such file or directory
Error opening /dev/fb0: No such device
Starting udevtar: dev/initctl: time stamp 2000-01-01 00:00:15 is 4.108551065 s in the future
tar: dev/vcsa: time stamp 2000-01-01 00:00:14 is 3.107421914 s in the future
tar: dev/vcs: time stamp 2000-01-01 00:00:14 is 3.107147256 s in the future
tar: dev/usbmon2: time stamp 2000-01-01 00:00:14 is 3.106628456 s in the future
tar: dev/usbmon1: time stamp 2000-01-01 00:00:14 is 3.106384316 s in the future
tar: dev/usbmon0: time stamp 2000-01-01 00:00:14 is 3.106170693 s in the future
tar: dev/usbdev2.1_ep81: time stamp 2000-01-01 00:00:14 is 3.10595707 s in the future
tar: dev/usbdev2.1_ep00: time stamp 2000-01-01 00:00:14 is 3.105743447 s in the future
tar: dev/usbdev1.1_ep81: time stamp 2000-01-01 00:00:14 is 3.105560341 s in the future
tar: dev/usbdev1.1_ep00: time stamp 2000-01-01 00:00:14 is 3.105346718 s in the future
tar: dev/bus/usb/002/001: time stamp 2000-01-01 00:00:14 is 3.10494999 s in the future
tar: dev/bus/usb/002: time stamp 2000-01-01 00:00:14 is 3.104766884 s in the future
tar: dev/bus/usb/001/001: time stamp 2000-01-01 00:00:14 is 3.104522744 s in the future
tar: dev/bus/usb/001: time stamp 2000-01-01 00:00:14 is 3.104126015 s in the future
tar: dev/bus/usb: time stamp 2000-01-01 00:00:14 is 3.10394291 s in the future
tar: dev/bus: time stamp 2000-01-01 00:00:14 is 3.10382084 s in the future
tar: dev/ttyS3: time stamp 2000-01-01 00:00:14 is 3.103668252 s in the future
tar: dev/ttyS2: time stamp 2000-01-01 00:00:14 is 3.103454629 s in the future
tar: dev/ttyS1: time stamp 2000-01-01 00:00:14 is 3.103241006 s in the future
tar: dev/ttyS0: time stamp 2000-01-01 00:00:14 is 3.102600137 s in the future
tar: dev/ttyGS0: time stamp 2000-01-01 00:00:14 is 3.102355996 s in the future
tar: dev/tty9: time stamp 2000-01-01 00:00:14 is 3.101898233 s in the future
tar: dev/tty8: time stamp 2000-01-01 00:00:14 is 3.101654092 s in the future
tar: dev/tty7: time stamp 2000-01-01 00:00:14 is 3.101440469 s in the future
tar: dev/tty63: time stamp 2000-01-01 00:00:14 is 3.101257364 s in the future
tar: dev/tty62: time stamp 2000-01-01 00:00:14 is 3.101043741 s in the future
tar: dev/tty61: time stamp 2000-01-01 00:00:14 is 3.100860635 s in the future
tar: dev/tty60: time stamp 2000-01-01 00:00:14 is 3.100647012 s in the future
tar: dev/tty6: time stamp 2000-01-01 00:00:14 is 3.100463907 s in the future
tar: dev/tty59: time stamp 2000-01-01 00:00:14 is 3.099853555 s in the future
tar: dev/tty58: time stamp 2000-01-01 00:00:14 is 3.099639932 s in the future
tar: dev/tty57: time stamp 2000-01-01 00:00:14 is 3.099426309 s in the future
tar: dev/tty56: time stamp 2000-01-01 00:00:14 is 3.099212686 s in the future
tar: dev/tty55: time stamp 2000-01-01 00:00:14 is 3.09890751 s in the future
tar: dev/tty54: time stamp 2000-01-01 00:00:14 is 3.098693887 s in the future
tar: dev/tty53: time stamp 2000-01-01 00:00:14 is 3.098480264 s in the future
tar: dev/tty52: time stamp 2000-01-01 00:00:14 is 3.098297159 s in the future
tar: dev/tty51: time stamp 2000-01-01 00:00:14 is 3.098083536 s in the future
tar: dev/tty50: time stamp 2000-01-01 00:00:14 is 3.09790043 s in the future
tar: dev/tty5: time stamp 2000-01-01 00:00:14 is 3.097595255 s in the future
tar: dev/tty49: time stamp 2000-01-01 00:00:14 is 3.097381632 s in the future
tar: dev/tty48: time stamp 2000-01-01 00:00:14 is 3.097198526 s in the future
tar: dev/tty47: time stamp 2000-01-01 00:00:14 is 3.09664921 s in the future
tar: dev/tty46: time stamp 2000-01-01 00:00:14 is 3.096374552 s in the future
tar: dev/tty45: time stamp 2000-01-01 00:00:14 is 3.096130411 s in the future
tar: dev/tty44: time stamp 2000-01-01 00:00:14 is 3.095947306 s in the future
tar: dev/tty43: time stamp 2000-01-01 00:00:14 is 3.095733683 s in the future
tar: dev/tty42: time stamp 2000-01-01 00:00:14 is 3.095550577 s in the future
tar: dev/tty41: time stamp 2000-01-01 00:00:14 is 3.095306437 s in the future
tar: dev/tty40: time stamp 2000-01-01 00:00:14 is 3.095092814 s in the future
tar: dev/tty4: time stamp 2000-01-01 00:00:14 is 3.094909708 s in the future
tar: dev/tty39: time stamp 2000-01-01 00:00:14 is 3.094726603 s in the future
tar: dev/tty38: time stamp 2000-01-01 00:00:14 is 3.09451298 s in the future
tar: dev/tty37: time stamp 2000-01-01 00:00:14 is 3.094329874 s in the future
tar: dev/tty36: time stamp 2000-01-01 00:00:14 is 2.760040322 s in the future
tar: dev/tty35: time stamp 2000-01-01 00:00:14 is 2.759826699 s in the future
tar: dev/tty34: time stamp 2000-01-01 00:00:14 is 2.759613076 s in the future
tar: dev/tty33: time stamp 2000-01-01 00:00:14 is 2.759399453 s in the future
tar: dev/tty32: time stamp 2000-01-01 00:00:14 is 2.759216348 s in the future
tar: dev/tty31: time stamp 2000-01-01 00:00:14 is 2.758361855 s in the future
tar: dev/tty30: time stamp 2000-01-01 00:00:14 is 2.758117715 s in the future
tar: dev/tty3: time stamp 2000-01-01 00:00:14 is 2.757904092 s in the future
tar: dev/tty29: time stamp 2000-01-01 00:00:14 is 2.757720986 s in the future
tar: dev/tty28: time stamp 2000-01-01 00:00:14 is 2.757507363 s in the future
tar: dev/tty27: time stamp 2000-01-01 00:00:14 is 2.75729374 s in the future
tar: dev/tty26: time stamp 2000-01-01 00:00:14 is 2.757080117 s in the future
tar: dev/tty25: time stamp 2000-01-01 00:00:14 is 2.756866494 s in the future
tar: dev/tty24: time stamp 2000-01-01 00:00:14 is 2.756652871 s in the future
tar: dev/tty23: time stamp 2000-01-01 00:00:14 is 2.756469766 s in the future
tar: dev/tty22: time stamp 2000-01-01 00:00:14 is 2.756256143 s in the future
tar: dev/tty21: time stamp 2000-01-01 00:00:14 is 2.756073037 s in the future
tar: dev/tty20: time stamp 2000-01-01 00:00:14 is 2.755889932 s in the future
tar: dev/tty2: time stamp 2000-01-01 00:00:14 is 2.755676309 s in the future
tar: dev/tty19: time stamp 2000-01-01 00:00:14 is 2.755493203 s in the future
tar: dev/tty18: time stamp 2000-01-01 00:00:14 is 2.755218545 s in the future
tar: dev/tty17: time stamp 2000-01-01 00:00:14 is 2.755004922 s in the future
tar: dev/tty16: time stamp 2000-01-01 00:00:14 is 2.754791299 s in the future
tar: dev/tty15: time stamp 2000-01-01 00:00:14 is 2.754577676 s in the future
tar: dev/tty14: time stamp 2000-01-01 00:00:14 is 2.753692666 s in the future
tar: dev/tty13: time stamp 2000-01-01 00:00:14 is 2.753356973 s in the future
tar: dev/tty12: time stamp 2000-01-01 00:00:14 is 2.75314335 s in the future
tar: dev/tty11: time stamp 2000-01-01 00:00:14 is 2.752929727 s in the future
tar: dev/tty10: time stamp 2000-01-01 00:00:14 is 2.752746621 s in the future
tar: dev/tty1: time stamp 2000-01-01 00:00:14 is 2.752532998 s in the future
tar: dev/tty0: time stamp 2000-01-01 00:00:14 is 2.752319375 s in the future
tar: dev/tty: time stamp 2000-01-01 00:00:14 is 2.752105752 s in the future
tar: dev/ptmx: time stamp 2000-01-01 00:00:14 is 2.751922647 s in the future
tar: dev/udev_network_queue: time stamp 2000-01-01 00:00:14 is 2.75125126 s in the future
tar: dev/rtc0: time stamp 2000-01-01 00:00:13 is 1.750671426 s in the future
tar: dev/console: time stamp 2000-01-01 00:00:13 is 1.750274698 s in the future
tar: dev/snd/timer: time stamp 2000-01-01 00:00:13 is 1.749816934 s in the future
tar: dev/snd: time stamp 2000-01-01 00:00:13 is 1.748901407 s in the future
tar: dev/mtd4ro: time stamp 2000-01-01 00:00:13 is 1.748657266 s in the future
tar: dev/mtd4: time stamp 2000-01-01 00:00:13 is 1.748413126 s in the future
tar: dev/mtd3ro: time stamp 2000-01-01 00:00:13 is 1.748199503 s in the future
tar: dev/mtd3: time stamp 2000-01-01 00:00:13 is 1.748016397 s in the future
tar: dev/mtd2ro: time stamp 2000-01-01 00:00:13 is 1.747802774 s in the future
tar: dev/mtd2: time stamp 2000-01-01 00:00:13 is 1.747497598 s in the future
tar: dev/mtd1ro: time stamp 2000-01-01 00:00:13 is 1.747192422 s in the future
tar: dev/mtd1: time stamp 2000-01-01 00:00:13 is 1.746978799 s in the future
tar: dev/mtd0ro: time stamp 2000-01-01 00:00:13 is 1.746795693 s in the future
tar: dev/mtd0: time stamp 2000-01-01 00:00:13 is 1.746551553 s in the future
tar: dev/watchdog: time stamp 2000-01-01 00:00:13 is 1.746368447 s in the future
tar: dev/ubi_ctrl: time stamp 2000-01-01 00:00:13 is 1.746124306 s in the future
tar: dev/psaux: time stamp 2000-01-01 00:00:13 is 1.410095264 s in the future
tar: dev/network_throughput: time stamp 2000-01-01 00:00:13 is 1.409881641 s in the future
tar: dev/network_latency: time stamp 2000-01-01 00:00:13 is 1.409668018 s in the future
tar: dev/cpu_dma_latency: time stamp 2000-01-01 00:00:13 is 1.409454395 s in the future
tar: dev/binder: time stamp 2000-01-01 00:00:13 is 1.40927129 s in the future
tar: dev/zero: time stamp 2000-01-01 00:00:13 is 1.409088184 s in the future
tar: dev/urandom: time stamp 2000-01-01 00:00:13 is 1.408844044 s in the future
tar: dev/random: time stamp 2000-01-01 00:00:13 is 1.408660938 s in the future
tar: dev/null: time stamp 2000-01-01 00:00:13 is 1.40838628 s in the future
tar: dev/mem: time stamp 2000-01-01 00:00:13 is 1.407928516 s in the future
tar: dev/kmsg: time stamp 2000-01-01 00:00:13 is 1.407562305 s in the future
tar: dev/kmem: time stamp 2000-01-01 00:00:13 is 1.407165577 s in the future
tar: dev/full: time stamp 2000-01-01 00:00:13 is 1.406738331 s in the future
tar: dev/input/uinput: time stamp 2000-01-01 00:00:13 is 1.406433155 s in the future
tar: dev/input/mice: time stamp 2000-01-01 00:00:13 is 1.406219532 s in the future
tar: dev/input/event1: time stamp 2000-01-01 00:00:13 is 1.406005909 s in the future
tar: dev/input/event0: time stamp 2000-01-01 00:00:13 is 1.405822803 s in the future
tar: dev/input: time stamp 2000-01-01 00:00:13 is 1.405639698 s in the future
tar: dev/i2c-3: time stamp 2000-01-01 00:00:13 is 1.40548711 s in the future
tar: dev/i2c-1: time stamp 2000-01-01 00:00:13 is 1.405273487 s in the future
tar: dev/null.old: time stamp 2000-01-01 00:00:13 is 1.404998829 s in the future
tar: dev/mtdblock4: time stamp 2000-01-01 00:00:13 is 1.404571583 s in the future
tar: dev/mtdblock1: time stamp 2000-01-01 00:00:13 is 1.404327442 s in the future
tar: dev/mmcblk0p2: time stamp 2000-01-01 00:00:12 is 0.403930714 s in the future
tar: dev/mmcblk0p1: time stamp 2000-01-01 00:00:12 is 0.403625537 s in the future
tar: dev/mtdblock3: time stamp 2000-01-01 00:00:12 is 0.403259326 s in the future
tar: dev/ram9: time stamp 2000-01-01 00:00:12 is 0.403015185 s in the future
tar: dev/ram8: time stamp 2000-01-01 00:00:12 is 0.40283208 s in the future
tar: dev/ram7: time stamp 2000-01-01 00:00:12 is 0.402618457 s in the future
tar: dev/ram6: time stamp 2000-01-01 00:00:12 is 0.402435351 s in the future
tar: dev/mtdblock0: time stamp 2000-01-01 00:00:12 is 0.402221728 s in the future
tar: dev/mtdblock2: time stamp 2000-01-01 00:00:12 is 0.401977588 s in the future
tar: dev/.udev/names/vcsa/\x2fclass\x2fvc\x2fvcsa: time stamp 2000-01-01 00:00:14 is 2.395416308 s in the future
tar: dev/.udev/names/vcsa: time stamp 2000-01-01 00:00:14 is 2.395141649 s in the future
tar: dev/.udev/names/vcs/\x2fclass\x2fvc\x2fvcs: time stamp 2000-01-01 00:00:14 is 2.394836474 s in the future
tar: dev/.udev/names/vcs: time stamp 2000-01-01 00:00:14 is 2.394653368 s in the future
tar: dev/.udev/names/usbmon2/\x2fclass\x2fusbmon\x2fusbmon2: time stamp 2000-01-01 00:00:14 is 2.39437871 s in the future
tar: dev/.udev/names/usbmon2: time stamp 2000-01-01 00:00:14 is 2.394195605 s in the future
tar: dev/.udev/names/usbmon1/\x2fclass\x2fusbmon\x2fusbmon1: time stamp 2000-01-01 00:00:14 is 2.393920946 s in the future
tar: dev/.udev/names/usbmon1: time stamp 2000-01-01 00:00:14 is 2.393676806 s in the future
tar: dev/.udev/names/usbmon0/\x2fclass\x2fusbmon\x2fusbmon0: time stamp 2000-01-01 00:00:14 is 2.39337163 s in the future
tar: dev/.udev/names/usbmon0: time stamp 2000-01-01 00:00:14 is 2.393158007 s in the future
tar: dev/.udev/names/usbdev2.1_ep81/\x2fclass\x2fusb_endpoint\x2fusbdev2.1_ep81: time stamp 2000-01-01 00:00:14 is 2.392913866 s in the future
tar: dev/.udev/names/usbdev2.1_ep81: time stamp 2000-01-01 00:00:14 is 2.392700243 s in the future
tar: dev/.udev/names/usbdev2.1_ep00/\x2fclass\x2fusb_endpoint\x2fusbdev2.1_ep00: time stamp 2000-01-01 00:00:14 is 2.391662646 s in the future
tar: dev/.udev/names/usbdev2.1_ep00: time stamp 2000-01-01 00:00:14 is 2.05725102 s in the future
tar: dev/.udev/names/usbdev1.1_ep81/\x2fclass\x2fusb_endpoint\x2fusbdev1.1_ep81: time stamp 2000-01-01 00:00:14 is 2.056915327 s in the future
tar: dev/.udev/names/usbdev1.1_ep81: time stamp 2000-01-01 00:00:14 is 2.056701704 s in the future
tar: dev/.udev/names/usbdev1.1_ep00/\x2fclass\x2fusb_endpoint\x2fusbdev1.1_ep00: time stamp 2000-01-01 00:00:14 is 2.056427046 s in the future
tar: dev/.udev/names/usbdev1.1_ep00: time stamp 2000-01-01 00:00:14 is 2.056213423 s in the future
tar: dev/.udev/names/bus\x2fusb\x2f002\x2f001/\x2fdevices\x2fplatform\x2fmusb_hdrc\x2fusb2: time stamp 2000-01-01 00:00:14 is 2.055938765 s in the future
tar: dev/.udev/names/bus\x2fusb\x2f002\x2f001/\x2fclass\x2fusb_device\x2fusbdev2.1: time stamp 2000-01-01 00:00:14 is 2.055694624 s in the future
tar: dev/.udev/names/bus\x2fusb\x2f002\x2f001: time stamp 2000-01-01 00:00:14 is 2.055481001 s in the future
tar: dev/.udev/names/bus\x2fusb\x2f001\x2f001/\x2fdevices\x2fplatform\x2fehci-omap.0\x2fusb1: time stamp 2000-01-01 00:00:14 is 2.055206343 s in the future
tar: dev/.udev/names/bus\x2fusb\x2f001\x2f001/\x2fclass\x2fusb_device\x2fusbdev1.1: time stamp 2000-01-01 00:00:14 is 2.054931685 s in the future
tar: dev/.udev/names/bus\x2fusb\x2f001\x2f001: time stamp 2000-01-01 00:00:14 is 2.054718062 s in the future
tar: dev/.udev/names/ttyS3/\x2fclass\x2ftty\x2fttyS3: time stamp 2000-01-01 00:00:14 is 2.054443404 s in the future
tar: dev/.udev/names/ttyS3: time stamp 2000-01-01 00:00:14 is 2.054260298 s in the future
tar: dev/.udev/names/ttyS2/\x2fclass\x2ftty\x2fttyS2: time stamp 2000-01-01 00:00:14 is 2.05398564 s in the future
tar: dev/.udev/names/ttyS2: time stamp 2000-01-01 00:00:14 is 2.053710982 s in the future
tar: dev/.udev/names/ttyS1/\x2fclass\x2ftty\x2fttyS1: time stamp 2000-01-01 00:00:14 is 2.053436324 s in the future
tar: dev/.udev/names/ttyS1: time stamp 2000-01-01 00:00:14 is 2.053222701 s in the future
tar: dev/.udev/names/ttyS0/\x2fclass\x2ftty\x2fttyS0: time stamp 2000-01-01 00:00:14 is 2.052948043 s in the future
tar: dev/.udev/names/ttyS0: time stamp 2000-01-01 00:00:14 is 2.05273442 s in the future
tar: dev/.udev/names/ttyGS0/\x2fclass\x2ftty\x2fttyGS0: time stamp 2000-01-01 00:00:14 is 2.052490279 s in the future
tar: dev/.udev/names/ttyGS0: time stamp 2000-01-01 00:00:14 is 2.05221562 s in the future
tar: dev/.udev/names/tty9/\x2fclass\x2ftty\x2ftty9: time stamp 2000-01-01 00:00:14 is 2.051940962 s in the future
tar: dev/.udev/names/tty9: time stamp 2000-01-01 00:00:14 is 2.051727339 s in the future
tar: dev/.udev/names/tty8/\x2fclass\x2ftty\x2ftty8: time stamp 2000-01-01 00:00:14 is 2.051483198 s in the future
tar: dev/.udev/names/tty8: time stamp 2000-01-01 00:00:14 is 2.051269575 s in the future
tar: dev/.udev/names/tty7/\x2fclass\x2ftty\x2ftty7: time stamp 2000-01-01 00:00:14 is 2.050994917 s in the future
tar: dev/.udev/names/tty7: time stamp 2000-01-01 00:00:14 is 2.050811812 s in the future
tar: dev/.udev/names/tty63/\x2fclass\x2ftty\x2ftty63: time stamp 2000-01-01 00:00:14 is 2.050567671 s in the future
tar: dev/.udev/names/tty63: time stamp 2000-01-01 00:00:14 is 2.050354048 s in the future
tar: dev/.udev/names/tty62/\x2fclass\x2ftty\x2ftty62: time stamp 2000-01-01 00:00:14 is 2.050109908 s in the future
tar: dev/.udev/names/tty62: time stamp 2000-01-01 00:00:14 is 2.049926802 s in the future
tar: dev/.udev/names/tty61/\x2fclass\x2ftty\x2ftty61: time stamp 2000-01-01 00:00:14 is 2.049652144 s in the future
tar: dev/.udev/names/tty61: time stamp 2000-01-01 00:00:14 is 2.049469039 s in the future
tar: dev/.udev/names/tty60/\x2fclass\x2ftty\x2ftty60: time stamp 2000-01-01 00:00:14 is 2.049224898 s in the future
tar: dev/.udev/names/tty60: time stamp 2000-01-01 00:00:14 is 2.04895024 s in the future
tar: dev/.udev/names/tty6/\x2fclass\x2ftty\x2ftty6: time stamp 2000-01-01 00:00:14 is 1.712768593 s in the future
tar: dev/.udev/names/tty6: time stamp 2000-01-01 00:00:14 is 1.71255497 s in the future
tar: dev/.udev/names/tty59/\x2fclass\x2ftty\x2ftty59: time stamp 2000-01-01 00:00:14 is 1.712280312 s in the future
tar: dev/.udev/names/tty59: time stamp 2000-01-01 00:00:14 is 1.712066689 s in the future
tar: dev/.udev/names/tty58/\x2fclass\x2ftty\x2ftty58: time stamp 2000-01-01 00:00:14 is 1.711822548 s in the future
tar: dev/.udev/names/tty58: time stamp 2000-01-01 00:00:14 is 1.711639442 s in the future
tar: dev/.udev/names/tty57/\x2fclass\x2ftty\x2ftty57: time stamp 2000-01-01 00:00:14 is 1.711364784 s in the future
tar: dev/.udev/names/tty57: time stamp 2000-01-01 00:00:14 is 1.711181679 s in the future
tar: dev/.udev/names/tty56/\x2fclass\x2ftty\x2ftty56: time stamp 2000-01-01 00:00:14 is 1.710907021 s in the future
tar: dev/.udev/names/tty56: time stamp 2000-01-01 00:00:14 is 1.710693398 s in the future
tar: dev/.udev/names/tty55/\x2fclass\x2ftty\x2ftty55: time stamp 2000-01-01 00:00:14 is 1.710449257 s in the future
tar: dev/.udev/names/tty55: time stamp 2000-01-01 00:00:14 is 1.710235634 s in the future
tar: dev/.udev/names/tty54/\x2fclass\x2ftty\x2ftty54: time stamp 2000-01-01 00:00:14 is 1.709991493 s in the future
tar: dev/.udev/names/tty54: time stamp 2000-01-01 00:00:14 is 1.709808388 s in the future
tar: dev/.udev/names/tty53/\x2fclass\x2ftty\x2ftty53: time stamp 2000-01-01 00:00:14 is 1.70953373 s in the future
tar: dev/.udev/names/tty53: time stamp 2000-01-01 00:00:14 is 1.709350624 s in the future
tar: dev/.udev/names/tty52/\x2fclass\x2ftty\x2ftty52: time stamp 2000-01-01 00:00:14 is 1.709106484 s in the future
tar: dev/.udev/names/tty52: time stamp 2000-01-01 00:00:14 is 1.708923378 s in the future
tar: dev/.udev/names/tty51/\x2fclass\x2ftty\x2ftty51: time stamp 2000-01-01 00:00:14 is 1.70864872 s in the future
tar: dev/.udev/names/tty51: time stamp 2000-01-01 00:00:14 is 1.708282508 s in the future
tar: dev/.udev/names/tty50/\x2fclass\x2ftty\x2ftty50: time stamp 2000-01-01 00:00:14 is 1.707977332 s in the future
tar: dev/.udev/names/tty50: time stamp 2000-01-01 00:00:14 is 1.707794227 s in the future
tar: dev/.udev/names/tty5/\x2fclass\x2ftty\x2ftty5: time stamp 2000-01-01 00:00:14 is 1.707519569 s in the future
tar: dev/.udev/names/tty5: time stamp 2000-01-01 00:00:14 is 1.707305946 s in the future
tar: dev/.udev/names/tty49/\x2fclass\x2ftty\x2ftty49: time stamp 2000-01-01 00:00:14 is 1.707061805 s in the future
tar: dev/.udev/names/tty49: time stamp 2000-01-01 00:00:14 is 1.706848182 s in the future
tar: dev/.udev/names/tty48/\x2fclass\x2ftty\x2ftty48: time stamp 2000-01-01 00:00:14 is 1.706573524 s in the future
tar: dev/.udev/names/tty48: time stamp 2000-01-01 00:00:14 is 1.706390419 s in the future
tar: dev/.udev/names/tty47/\x2fclass\x2ftty\x2ftty47: time stamp 2000-01-01 00:00:14 is 1.70611576 s in the future
tar: dev/.udev/names/tty47: time stamp 2000-01-01 00:00:14 is 1.705932655 s in the future
tar: dev/.udev/names/tty46/\x2fclass\x2ftty\x2ftty46: time stamp 2000-01-01 00:00:14 is 1.705688514 s in the future
tar: dev/.udev/names/tty46: time stamp 2000-01-01 00:00:14 is 1.705505409 s in the future
tar: dev/.udev/names/tty45/\x2fclass\x2ftty\x2ftty45: time stamp 2000-01-01 00:00:14 is 1.705230751 s in the future
tar: dev/.udev/names/tty45: time stamp 2000-01-01 00:00:14 is 1.705047645 s in the future
tar: dev/.udev/names/tty44/\x2fclass\x2ftty\x2ftty44: time stamp 2000-01-01 00:00:14 is 1.704803505 s in the future
tar: dev/.udev/names/tty44: time stamp 2000-01-01 00:00:14 is 1.704589882 s in the future
tar: dev/.udev/names/tty43/\x2fclass\x2ftty\x2ftty43: time stamp 2000-01-01 00:00:14 is 1.704315223 s in the future
tar: dev/.udev/names/tty43: time stamp 2000-01-01 00:00:14 is 1.7041016 s in the future
tar: dev/.udev/names/tty42/\x2fclass\x2ftty\x2ftty42: time stamp 2000-01-01 00:00:14 is 1.368408249 s in the future
tar: dev/.udev/names/tty42: time stamp 2000-01-01 00:00:14 is 1.368103073 s in the future
tar: dev/.udev/names/tty41/\x2fclass\x2ftty\x2ftty41: time stamp 2000-01-01 00:00:14 is 1.367828415 s in the future
tar: dev/.udev/names/tty41: time stamp 2000-01-01 00:00:14 is 1.367614792 s in the future
tar: dev/.udev/names/tty40/\x2fclass\x2ftty\x2ftty40: time stamp 2000-01-01 00:00:14 is 1.367340134 s in the future
tar: dev/.udev/names/tty40: time stamp 2000-01-01 00:00:14 is 1.367157028 s in the future
tar: dev/.udev/names/tty4/\x2fclass\x2ftty\x2ftty4: time stamp 2000-01-01 00:00:14 is 1.36688237 s in the future
tar: dev/.udev/names/tty4: time stamp 2000-01-01 00:00:14 is 1.366699265 s in the future
tar: dev/.udev/names/tty39/\x2fclass\x2ftty\x2ftty39: time stamp 2000-01-01 00:00:14 is 1.366424606 s in the future
tar: dev/.udev/names/tty39: time stamp 2000-01-01 00:00:14 is 1.366241501 s in the future
tar: dev/.udev/names/tty38/\x2fclass\x2ftty\x2ftty38: time stamp 2000-01-01 00:00:14 is 1.365966843 s in the future
tar: dev/.udev/names/tty38: time stamp 2000-01-01 00:00:14 is 1.36575322 s in the future
tar: dev/.udev/names/tty37/\x2fclass\x2ftty\x2ftty37: time stamp 2000-01-01 00:00:14 is 1.365509079 s in the future
tar: dev/.udev/names/tty37: time stamp 2000-01-01 00:00:14 is 1.365325974 s in the future
tar: dev/.udev/names/tty36/\x2fclass\x2ftty\x2ftty36: time stamp 2000-01-01 00:00:14 is 1.365081833 s in the future
tar: dev/.udev/names/tty36: time stamp 2000-01-01 00:00:14 is 1.36486821 s in the future
tar: dev/.udev/names/tty35/\x2fclass\x2ftty\x2ftty35: time stamp 2000-01-01 00:00:14 is 1.364532516 s in the future
tar: dev/.udev/names/tty35: time stamp 2000-01-01 00:00:14 is 1.364318892 s in the future
tar: dev/.udev/names/tty34/\x2fclass\x2ftty\x2ftty34: time stamp 2000-01-01 00:00:14 is 1.364074752 s in the future
tar: dev/.udev/names/tty34: time stamp 2000-01-01 00:00:14 is 1.363891646 s in the future
tar: dev/.udev/names/tty33/\x2fclass\x2ftty\x2ftty33: time stamp 2000-01-01 00:00:14 is 1.363616988 s in the future
tar: dev/.udev/names/tty33: time stamp 2000-01-01 00:00:14 is 1.363372848 s in the future
tar: dev/.udev/names/tty32/\x2fclass\x2ftty\x2ftty32: time stamp 2000-01-01 00:00:14 is 1.363067672 s in the future
tar: dev/.udev/names/tty32: time stamp 2000-01-01 00:00:14 is 1.362854049 s in the future
tar: dev/.udev/names/tty31/\x2fclass\x2ftty\x2ftty31: time stamp 2000-01-01 00:00:14 is 1.362579391 s in the future
tar: dev/.udev/names/tty31: time stamp 2000-01-01 00:00:14 is 1.362365768 s in the future
tar: dev/.udev/names/tty30/\x2fclass\x2ftty\x2ftty30: time stamp 2000-01-01 00:00:14 is 1.362121627 s in the future
tar: dev/.udev/names/tty30: time stamp 2000-01-01 00:00:14 is 1.361938521 s in the future
tar: dev/.udev/names/tty3/\x2fclass\x2ftty\x2ftty3: time stamp 2000-01-01 00:00:14 is 1.361663863 s in the future
tar: dev/.udev/names/tty3: time stamp 2000-01-01 00:00:14 is 1.361480758 s in the future
tar: dev/.udev/names/tty29/\x2fclass\x2ftty\x2ftty29: time stamp 2000-01-01 00:00:14 is 1.3612061 s in the future
tar: dev/.udev/names/tty29: time stamp 2000-01-01 00:00:14 is 1.361022994 s in the future
tar: dev/.udev/names/tty28/\x2fclass\x2ftty\x2ftty28: time stamp 2000-01-01 00:00:14 is 1.360778854 s in the future
tar: dev/.udev/names/tty28: time stamp 2000-01-01 00:00:14 is 1.360595748 s in the future
tar: dev/.udev/names/tty27/\x2fclass\x2ftty\x2ftty27: time stamp 2000-01-01 00:00:14 is 1.360290572 s in the future
tar: dev/.udev/names/tty27: time stamp 2000-01-01 00:00:14 is 1.360107467 s in the future
tar: dev/.udev/names/tty26/\x2fclass\x2ftty\x2ftty26: time stamp 2000-01-01 00:00:14 is 1.359832809 s in the future
tar: dev/.udev/names/tty26: time stamp 2000-01-01 00:00:14 is 1.359649703 s in the future
tar: dev/.udev/names/tty25/\x2fclass\x2ftty\x2ftty25: time stamp 2000-01-01 00:00:14 is 1.024108935 s in the future
tar: dev/.udev/names/tty25: time stamp 2000-01-01 00:00:14 is 1.023895312 s in the future
tar: dev/.udev/names/tty24/\x2fclass\x2ftty\x2ftty24: time stamp 2000-01-01 00:00:14 is 1.023620654 s in the future
tar: dev/.udev/names/tty24: time stamp 2000-01-01 00:00:14 is 1.023376514 s in the future
tar: dev/.udev/names/tty23/\x2fclass\x2ftty\x2ftty23: time stamp 2000-01-01 00:00:14 is 1.023071338 s in the future
tar: dev/.udev/names/tty23: time stamp 2000-01-01 00:00:14 is 1.022857715 s in the future
tar: dev/.udev/names/tty22/\x2fclass\x2ftty\x2ftty22: time stamp 2000-01-01 00:00:14 is 1.022613574 s in the future
tar: dev/.udev/names/tty22: time stamp 2000-01-01 00:00:14 is 1.022399951 s in the future
tar: dev/.udev/names/tty21/\x2fclass\x2ftty\x2ftty21: time stamp 2000-01-01 00:00:14 is 1.022155811 s in the future
tar: dev/.udev/names/tty21: time stamp 2000-01-01 00:00:14 is 1.021972705 s in the future
tar: dev/.udev/names/tty20/\x2fclass\x2ftty\x2ftty20: time stamp 2000-01-01 00:00:14 is 1.021698047 s in the future
tar: dev/.udev/names/tty20: time stamp 2000-01-01 00:00:14 is 1.021484424 s in the future
tar: dev/.udev/names/tty2/\x2fclass\x2ftty\x2ftty2: time stamp 2000-01-01 00:00:14 is 1.021240284 s in the future
tar: dev/.udev/names/tty2: time stamp 2000-01-01 00:00:14 is 1.021057178 s in the future
tar: dev/.udev/names/tty19/\x2fclass\x2ftty\x2ftty19: time stamp 2000-01-01 00:00:14 is 1.020690967 s in the future
tar: dev/.udev/names/tty19: time stamp 2000-01-01 00:00:14 is 1.020507861 s in the future
tar: dev/.udev/names/tty18/\x2fclass\x2ftty\x2ftty18: time stamp 2000-01-01 00:00:14 is 1.020263721 s in the future
tar: dev/.udev/names/tty18: time stamp 2000-01-01 00:00:14 is 1.020050098 s in the future
tar: dev/.udev/names/tty17/\x2fclass\x2ftty\x2ftty17: time stamp 2000-01-01 00:00:14 is 1.019805957 s in the future
tar: dev/.udev/names/tty17: time stamp 2000-01-01 00:00:14 is 1.019622852 s in the future
tar: dev/.udev/names/tty16/\x2fclass\x2ftty\x2ftty16: time stamp 2000-01-01 00:00:14 is 1.019348194 s in the future
tar: dev/.udev/names/tty16: time stamp 2000-01-01 00:00:14 is 1.019165088 s in the future
tar: dev/.udev/names/tty15/\x2fclass\x2ftty\x2ftty15: time stamp 2000-01-01 00:00:14 is 1.01889043 s in the future
tar: dev/.udev/names/tty15: time stamp 2000-01-01 00:00:14 is 1.018615772 s in the future
tar: dev/.udev/names/tty14/\x2fclass\x2ftty\x2ftty14: time stamp 2000-01-01 00:00:14 is 1.018341114 s in the future
tar: dev/.udev/names/tty14: time stamp 2000-01-01 00:00:14 is 1.018158009 s in the future
tar: dev/.udev/names/tty13/\x2fclass\x2ftty\x2ftty13: time stamp 2000-01-01 00:00:14 is 1.017883351 s in the future
tar: dev/.udev/names/tty13: time stamp 2000-01-01 00:00:14 is 1.017700245 s in the future
tar: dev/.udev/names/tty12/\x2fclass\x2ftty\x2ftty12: time stamp 2000-01-01 00:00:14 is 1.017456105 s in the future
tar: dev/.udev/names/tty12: time stamp 2000-01-01 00:00:14 is 1.017272999 s in the future
tar: dev/.udev/names/tty11/\x2fclass\x2ftty\x2ftty11: time stamp 2000-01-01 00:00:14 is 1.016998341 s in the future
tar: dev/.udev/names/tty11: time stamp 2000-01-01 00:00:14 is 1.016815236 s in the future
tar: dev/.udev/names/tty10/\x2fclass\x2ftty\x2ftty10: time stamp 2000-01-01 00:00:14 is 1.016540578 s in the future
tar: dev/.udev/names/tty10: time stamp 2000-01-01 00:00:14 is 1.016326955 s in the future
tar: dev/.udev/names/tty1/\x2fclass\x2ftty\x2ftty1: time stamp 2000-01-01 00:00:14 is 1.016082814 s in the future
tar: dev/.udev/names/tty1: time stamp 2000-01-01 00:00:14 is 1.015869191 s in the future
tar: dev/.udev/names/tty0/\x2fclass\x2ftty\x2ftty0: time stamp 2000-01-01 00:00:14 is 1.01562505 s in the future
tar: dev/.udev/names/tty0: time stamp 2000-01-01 00:00:14 is 1.015441945 s in the future
tar: dev/.udev/names/tty/\x2fclass\x2ftty\x2ftty: time stamp 2000-01-01 00:00:14 is 0.679748573 s in the future
tar: dev/.udev/names/tty: time stamp 2000-01-01 00:00:14 is 0.67953495 s in the future
tar: dev/.udev/names/ptmx/\x2fclass\x2ftty\x2fptmx: time stamp 2000-01-01 00:00:14 is 0.679260291 s in the future
tar: dev/.udev/names/ptmx: time stamp 2000-01-01 00:00:14 is 0.679077186 s in the future
tar: dev/.udev/names: time stamp 2000-01-01 00:00:14 is 0.66036991 s in the future
tar: dev/.udev/db: time stamp 2000-01-01 00:00:14 is 0.64739994 s in the future
tar: dev/.udev/uevent_seqnum: time stamp 2000-01-01 00:00:14 is 0.647064247 s in the future
tar: dev/.udev/failed: time stamp 2000-01-01 00:00:14 is 0.644897498 s in the futur[ 36.670349] udevd version 124 started
e
tar: dev/.udev: time stamp 2000-01-01 00:00:14 is 0.644683875 s in the future
tar: dev: time stamp 2000-01-01 00:00:15 is 1.644378699 s in the future
Remounting root file system…
[ 37.878631] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[ 37.886505] Buffer I/O error on device mtdblock0, logical block 0
[ 37.892822] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 8
[ 37.900665] Buffer I/O error on device mtdblock0, logical block 1
[ 37.906982] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 16
[ 37.914855] Buffer I/O error on device mtdblock0, logical block 2
[ 37.921173] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 24
[ 37.929046] Buffer I/O error on device mtdblock0, logical block 3
[ 38.047668] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[ 38.055511] Buffer I/O error on device mtdblock0, logical block 0
WARNING: Couldn’t open directory /lib/modules/2.6.29-omap1: No such file or directory
FATAL: Could not open /lib/modules/2.6.29-omap1/modules.dep.temp for writing: No such file or directory
ALSA: Restoring mixer settings…
Configuring network interfaces… /usr/sbin/alsactl: load_state:1616: No soundcards found…
eth0: unknown interface: No such device
eth0 No such device
done.
Starting portmap daemon: portmap.
Unknown HZ value! (66) Assume 100.
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
Fri Jun 12 13:04:00 BST 2009
INIT: Entering runlevel: 5
Configuring leds:
beagleboard::pmu_st: none
beagleboard::usr0: heartbeat
beagleboard::usr1: mmc0
Starting Dropbear SSH server: modprobe: FATAL: Could not load /lib/modules/2.6.29-omap1/modules.dep: No such file or directory
dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[ ok ]
Starting Connection Manager
Running ntpdate to synchronize clockError : Temporary failure in name resolution
Starting GPE display manager: gpe-dm
I don’t have any display engine in my board,
I want to know what exactly this problem. and how to overcome this issue.
I am planning to boot my kernel image with ext3 file system. Is there any ext3 file system available otherthan Angstrom rootfs?
How to build this rootfs.
Sanjeev
That's ancient!
Okay, lets see whats going on here:
Okay this needs to be fixed otherwise your hardware won’t be detected and work: your rootfs doesn’t have a /lib/modules/… directory for this kernel. Since you are building from source you should run “make modules” from the linux kernel source directory and then copy across the relevant files to your rootfs.
“modprobe: FATAL: Could not load /lib/modules/2.6.29-omap1/modules.dep: No such file or directory”
You haven’t got a framebuffer device - Angstrom is trying to show a graphical splash screen - doesn’t matter though…
“Error opening /dev/fb0: No such device”
Your clock is skewing because of the TWL not having any battery backup… you can ignore these messages…
“Starting udevtar: dev/initctl: time stamp 2000-01-01 00:00:15 is 4.108551065 s in the future”
Next up I imagine that because the kernel can’t find its modules it can’t load the USB dongle’s drivers which is why there is no eth0 interface. This needs to be fixed if you want to get your board networked up… otherwise you can ignore these errors…
“Configuring network interfaces…”
“eth0: unknown interface: No such device”
“eth0 No such device”
“done.”
Assuming you also have two LEDs connected to the board then one of them should be flashing every second or so to indicate the kernel is still alive. If you’ve got the LED then make sure it keeps flashing even after you think the board has stopped responding… if its flashing then the kernel is still alive…
“Configuring leds:”
" beagleboard::usr0: heartbeat"
SSH Daemon is starting… this is good… and bad… again modules can’t be found. This time they are probably encryption / crypto modules… If you want to SSH onto your board then again this will need to be fixed (the fix from before should also fix this problem)
“Starting Dropbear SSH server: modprobe: FATAL: Could not load /lib/modules/2.6.29-omap1/modules.dep: No such file or directory”
“dropbear.”
None of the network interfaces are working properly - name resolution means that your board can’t convert a hostname (like www.beagleboard.org) into its IP address… in reality you probably don’t even have basic non-routed network connectivity so once your modules are in place and your network drivers are loaded properly this issue will probably disappear…
“Starting Connection Manager”
“Running ntpdate to synchronize clockError : Temporary failure in name resolution”
And then shortly after that you get no more output… Since you changed your serial console to be a different port you should probably examine your rootfs and see if getty is being run on your new serial console. So:
  1. Look at /etc/inittab and add an entry like this “S:12345:respawn:/sbin/getty 115200 ttyS0”
  2. Look at /etc/securetty and add an entry for ttyS0 so that you can log on as the root user.
Let me know how it goes… (and please don’t post multiple times as it bothers everyone else and confuses me :slight_smile:
Good luck!
