[beagleboard] Kernel boot stops
My kernel boot stops after syslogd/Klogd,
here is the log, Please let me know the problem.
## Booting kernel from Legacy Image at 80300000 …
Image Name: Linux-2.6.29-omap1
Data Size: 2762876 Bytes = 2.6 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Uncompressing Linux…
[ 0.000000] Linux version 2.6.29-omap1 (root@INETFI-LINUX-MC4) (gcc version 4.2.1 (CodeSourcery Sourcery G++ Lite 2007q3-51)) #5 Wed Jul 1 29
[ 0.000000] CPU: ARMv7 Processor [411fc082] revision 2 (ARMv7), cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: OMAP3 Beagle Board
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] OMAP3430 ES2.1
[ 0.000000] SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8 mem=128M noinitrd rw root=/dev/mmcblk0p2 rootdelay=5 rootfstype=ext3
[ 0.000000] Clocking rate (Crystal/DPLL/ARM core): 26.0/332/500 MHz
[ 0.000000] GPMC revision 5.0
[ 0.000000] IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
[ 0.000000] Total of 96 interrupts on 1 active controller
[ 0.000000] OMAP34xx GPIO hardware version 2.5
[ 0.000000] PID hash table entries: 512 (order: 9, 2048 bytes)
[ 0.000000] OMAP clockevent source: GPTIMER12 at 32768 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 128MB = 128MB total
[ 0.000000] Memory: 123888KB available (5124K code, 559K data, 188K init)
[ 0.000000] Calibrating delay loop… 485.26 BogoMIPS (lpj=1896448)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] net_namespace: 1036 bytes
[ 0.000000] regulator: core version 0.5
[ 0.000000] NET: Registered protocol family 16
[ 0.000000] Found NAND on CS0
[ 0.000000] Registering NAND on CS0
[ 26.266632] OMAP DMA hardware revision 4.0
[ 26.305755] bio: create slab at 0
[ 26.308105] i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
[ 26.311889] twl4030: PIH (irq 7) chaining IRQs 368…375
[ 26.311920] twl4030: power (irq 373) chaining IRQs 376…383
[ 26.312438] twl4030: gpio (irq 368) chaining IRQs 384…401
[ 26.316497] regulator: VMMC1: 1850 ↔ 3150 mV normal standby
[ 26.317443] regulator: VDAC: 1800 mV normal standby
[ 26.318298] regulator: VUSB1V5: 1500 ↔ 0 mV normal standby
[ 26.319122] regulator: VUSB1V8: 1800 ↔ 0 mV normal standby
[ 26.319946] regulator: VUSB3V1: 3100 ↔ 0 mV normal standby
[ 26.320770] regulator: VPLL2: 1800 mV normal standby
[ 26.321594] regulator: VSIM: 1800 ↔ 3000 mV normal standby
[ 26.321777] i2c_omap i2c_omap.3: bus 3 rev3.12 at 100 kHz
[ 26.323760] SCSI subsystem initialized
[ 26.324890] twl4030_usb twl4030_usb: Initialized TWL4030 USB module
[ 26.326324] usbcore: registered new interface driver usbfs
[ 26.326904] usbcore: registered new interface driver hub
[ 26.327301] usbcore: registered new device driver usb
[ 26.330230] Bluetooth: Core ver 2.14
[ 26.330810] NET: Registered protocol family 31
[ 26.330810] Bluetooth: HCI device and connection manager initialized
[ 26.330841] Bluetooth: HCI socket layer initialized
[ 26.331542] cfg80211: Using static regulatory domain info
[ 26.331573] cfg80211: Regulatory domain: US
[ 26.331604] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 26.331604] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 26.331634] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 26.331634] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 26.331665] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 26.331695] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 26.331695] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 26.331726] cfg80211: Calling CRDA for country: US
[ 26.334960] musb_hdrc: version 6.0, musb-dma, otg (peripheral+host), debug=0
[ 26.335662] musb_hdrc: USB OTG mode controller at d80ab000 using DMA, IRQ 92
[ 26.336822] NET: Registered protocol family 2
[ 26.337036] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 26.337646] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 26.337799] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 26.337890] TCP: Hash tables configured (established 4096 bind 4096)
[ 26.337921] TCP reno registered
[ 26.338165] NET: Registered protocol family 1
[ 26.342437] VFS: Disk quotas dquot_6.5.2
[ 26.342529] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 26.343048] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 26.343719] JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
[ 26.344512] msgmni has been set to 242
[ 26.349304] alg: No test for stdrng (krng)
[ 26.349426] io scheduler noop registered
[ 26.349426] io scheduler anticipatory registered
[ 26.349456] io scheduler deadline registered
[ 26.349609] io scheduler cfq registered (default)
[ 26.372406] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 26.394409] serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
[ 26.394439] console [ttyS0] enabled
[ 26.882141] serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
[ 26.909851] serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
[ 26.928649] brd: module loaded
[ 26.937286] loop: module loaded
[ 26.940856] usbcore: registered new interface driver catc
[ 26.946319] catc: v2.8:CATC EL1210A NetMate USB Ethernet driver
[ 26.953063] usbcore: registered new interface driver kaweth
[ 26.958740] pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
[ 26.966583] usbcore: registered new interface driver pegasus
[ 26.972320] rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
[ 26.979553] usbcore: registered new interface driver rtl8150
[ 26.985504] usbcore: registered new interface driver asix
[ 26.991241] usbcore: registered new interface driver cdc_ether
[ 26.997436] usbcore: registered new interface driver dm9601
[ 27.003356] usbcore: registered new interface driver smsc95xx
[ 27.009399] usbcore: registered new interface driver gl620a
[ 27.015350] usbcore: registered new interface driver net1080
[ 27.021331] usbcore: registered new interface driver plusb
[ 27.027160] usbcore: registered new interface driver rndis_host
[ 27.033386] usbcore: registered new interface driver cdc_subset
[ 27.039703] Broadcom 43xx driver loaded [ Features: L, Firmware-ID: FW13 ]
[ 27.047088] usbcore: registered new interface driver zd1211rw
[ 27.053161] usbcore: registered new interface driver rtl8187
[ 27.059234] usbcore: registered new interface driver rndis_wlan
[ 27.065490] usbcore: registered new interface driver zd1201
[ 27.071411] usbcore: registered new interface driver usb8xxx
[ 27.077453] usbcore: registered new interface driver rt2500usb
[ 27.083648] usbcore: registered new interface driver rt73usb
[ 27.089660] usbcore: registered new interface driver p54usb
[ 27.095275] i2c /dev entries driver
[ 27.100341] Driver ‘sd’ needs updating - please use bus_type methods
[ 27.107055] Driver ‘sr’ needs updating - please use bus_type methods
[ 27.114501] omap2-nand driver initializing
[ 27.118896] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
[ 27.127990] cmdlinepart partition parsing not available
[ 27.133239] Creating 5 MTD partitions on “omap2-nand”:
[ 27.138458] 0x000000000000-0x000000080000 : “X-Loader”
[ 27.145507] 0x000000080000-0x000000260000 : “U-Boot”
[ 27.152526] 0x000000260000-0x000000280000 : “U-Boot Env”
[ 27.159210] 0x000000280000-0x000000680000 : “Kernel”
[ 27.167053] 0x000000680000-0x000010000000 : “File System”
[ 27.277618] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 27.284667] ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
[ 27.291320] ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 1
[ 27.299194] ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
[ 27.315002] ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
[ 27.321594] usb usb1: configuration #1 chosen from 1 choice
[ 27.327728] hub 1-0:1.0: USB hub found
[ 27.331634] hub 1-0:1.0: 3 ports detected
[ 27.337799] Initializing USB Mass Storage driver…
[ 27.343139] usbcore: registered new interface driver usb-storage
[ 27.349273] USB Mass Storage support registered.
[ 27.354003] g_cdc gadget: using random self ethernet address
[ 27.359710] g_cdc gadget: using random host ethernet address
[ 27.366241] usb0: MAC 22:3b:03:0f:59:61
[ 27.370147] usb0: HOST MAC 72:46:5b:01:7d:ec
[ 27.375000] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 27.382659] g_cdc gadget: g_cdc ready
[ 27.386383] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 27.392364] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 2
[ 27.400451] usb usb2: configuration #1 chosen from 1 choice
[ 27.406585] hub 2-0:1.0: USB hub found
[ 27.410491] hub 2-0:1.0: 1 port detected
[ 27.416473] mice: PS/2 mouse device common for all mice
[ 27.422485] input: gpio-keys as /class/input/input0
[ 27.429840] input: twl4030_pwrbutton as /class/input/input1
[ 27.436950] twl4030_rtc twl4030_rtc: rtc core: registered twl4030_rtc as rtc0
[ 27.444305] twl4030_rtc twl4030_rtc: Power up reset detected.
[ 27.450500] twl4030_rtc twl4030_rtc: Enabling TWL4030-RTC.
[ 27.458343] OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
[ 27.464782] Bluetooth: HCI UART driver ver 2.2
[ 27.469268] Bluetooth: HCI H4 protocol initialized
[ 27.474121] Bluetooth: HCI BCSP protocol initialized
[ 27.479156] Bluetooth: HCILL protocol initialized
[ 27.483886] Bluetooth: Broadcom Blutonium firmware driver ver 1.2
[ 27.490356] usbcore: registered new interface driver bcm203x
[ 27.496124] Bluetooth: Digianswer Bluetooth USB driver ver 0.10
[ 27.502380] usbcore: registered new interface driver bpa10x
[ 27.508087] Bluetooth: BlueFRITZ! USB driver ver 1.2
[ 27.513702] usbcore: registered new interface driver bfusb
[ 27.519287] Bluetooth: Generic Bluetooth USB driver ver 0.4
[ 27.525238] usbcore: registered new interface driver btusb
[ 27.530853] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 27.538116] mmci-omap-hs mmci-omap-hs.0: Failed to get debounce clock
[ 27.652191] Registered led device: beagleboard::usr0
[ 27.657623] Registered led device: beagleboard::usr1
[ 27.663513] Registered led device: beagleboard::pmu_stat
[ 27.675476] usbcore: registered new interface driver usbhid
[ 27.681121] usbhid: v2.6:USB HID core driver
[ 27.686614] Advanced Linux Sound Architecture Driver Version 1.0.18a.
[ 27.694000] usbcore: registered new interface driver snd-usb-audio
[ 27.700683] ALSA device list:
[ 27.703674] No soundcards found.
[ 27.707855] oprofile: using arm/armv7
[ 27.711791] TCP cubic registered
[ 27.715148] NET: Registered protocol family 17
[ 27.719635] NET: Registered protocol family 15
[ 27.724212] Bluetooth: L2CAP ver 2.11
[ 27.727874] Bluetooth: L2CAP socket layer initialized
[ 27.733001] Bluetooth: SCO (Voice Link) ver 0.6
[ 27.737609] Bluetooth: SCO socket layer initialized
[ 27.742675] Bluetooth: RFCOMM socket layer initialized
[ 27.747924] Bluetooth: RFCOMM TTY layer initialized
[ 27.752868] Bluetooth: RFCOMM ver 1.10
[ 27.756652] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 27.762023] Bluetooth: BNEP filters: protocol multicast
[ 27.767272] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 27.781707] RPC: Registered udp transport module.
[ 27.786560] RPC: Registered tcp transport module.
[ 27.791351] lib80211: common routines for IEEE802.11 drivers
[ 27.797119] ThumbEE CPU extension supported.
[ 27.801452] Power Management for TI OMAP3.
[ 27.806121] SmartReflex driver initialized
[ 27.817565] Disabling unused clock “sr2_fck”
[ 27.821868] Disabling unused clock “sr1_fck”
[ 27.826263] Disabling unused clock “mcbsp_fck”
[ 27.830780] Disabling unused clock “mcbsp_fck”
[ 27.835235] Disabling unused clock “mcbsp_fck”
[ 27.839752] Disabling unused clock “mcbsp_ick”
[ 27.844238] Disabling unused clock “mcbsp_ick”
[ 27.848724] Disabling unused clock “mcbsp_ick”
[ 27.853210] Disabling unused clock “gpt2_ick”
[ 27.857604] Disabling unused clock “gpt3_ick”
[ 27.862030] Disabling unused clock “gpt4_ick”
[ 27.866424] Disabling unused clock “gpt5_ick”
[ 27.870819] Disabling unused clock “gpt6_ick”
[ 27.875213] Disabling unused clock “gpt7_ick”
[ 27.879608] Disabling unused clock “gpt8_ick”
[ 27.884002] Disabling unused clock “gpt9_ick”
[ 27.888427] Disabling unused clock “wdt3_ick”
[ 27.892822] Disabling unused clock “wdt3_fck”
[ 27.897216] Disabling unused clock “gpio2_dbck”
[ 27.901824] Disabling unused clock “gpio3_dbck”
[ 27.906372] Disabling unused clock “gpio4_dbck”
[ 27.910980] Disabling unused clock “gpio5_dbck”
[ 27.915527] Disabling unused clock “gpio6_dbck”
[ 27.920104] Disabling unused clock “gpt9_fck”
[ 27.924530] Disabling unused clock “gpt8_fck”
[ 27.928894] Disabling unused clock “gpt7_fck”
[ 27.933319] Disabling unused clock “gpt6_fck”
[ 27.937683] Disabling unused clock “gpt5_fck”
[ 27.942108] Disabling unused clock “gpt4_fck”
[ 27.946502] Disabling unused clock “gpt3_fck”
[ 27.950897] Disabling unused clock “gpt2_fck”
[ 27.955291] Disabling unused clock “gpt1_ick”
[ 27.959716] Disabling unused clock “wdt1_ick”
[ 27.964111] Disabling unused clock “wdt2_ick”
[ 27.968505] Disabling unused clock “wdt2_fck”
[ 27.972900] Disabling unused clock “gpio1_dbck”
[ 27.977478] Disabling unused clock “gpt1_fck”
[ 27.981903] Disabling unused clock “cam_ick”
[ 27.986236] Disabling unused clock “cam_mclk”
[ 27.990661] Disabling unused clock “dss_ick”
[ 27.994995] Disabling unused clock “dss_96m_fck”
[ 27.999664] Disabling unused clock “dss1_alwon_fck”
[ 28.004608] Disabling unused clock “des1_ick”
[ 28.009002] Disabling unused clock “sha11_ick”
[ 28.013488] Disabling unused clock “rng_ick”
[ 28.017791] Disabling unused clock “aes1_ick”
[ 28.022186] Disabling unused clock “ssi_ick”
[ 28.026519] Disabling unused clock “mailboxes_ick”
[ 28.031341] Disabling unused clock “mcbsp_ick”
[ 28.035827] Disabling unused clock “mcbsp_ick”
[ 28.040313] Disabling unused clock “gpt10_ick”
[ 28.044799] Disabling unused clock “gpt11_ick”
[ 28.049316] Disabling unused clock “i2c_ick”
[ 28.053619] Disabling unused clock “mcspi_ick”
[ 28.058105] Disabling unused clock “mcspi_ick”
[ 28.062591] Disabling unused clock “mcspi_ick”
[ 28.067077] Disabling unused clock “mcspi_ick”
[ 28.071563] Disabling unused clock “hdq_ick”
[ 28.075866] Disabling unused clock “mspro_ick”
[ 28.080352] Disabling unused clock “des2_ick”
[ 28.084747] Disabling unused clock “sha12_ick”
[ 28.089263] Disabling unused clock “aes2_ick”
[ 28.093627] Disabling unused clock “icr_ick”
[ 28.097961] Disabling unused clock “pka_ick”
[ 28.102264] Disabling unused clock “ssi_ssr_fck”
[ 28.106933] Disabling unused clock “hdq_fck”
[ 28.111236] Disabling unused clock “mcspi_fck”
[ 28.115722] Disabling unused clock “mcspi_fck”
[ 28.120239] Disabling unused clock “mcspi_fck”
[ 28.124694] Disabling unused clock “mcspi_fck”
[ 28.129211] Disabling unused clock “mcbsp_fck”
[ 28.133666] Disabling unused clock “mcbsp_fck”
[ 28.138183] Disabling unused clock “i2c_fck”
[ 28.142486] Disabling unused clock “mspro_fck”
[ 28.146972] Disabling unused clock “gpt11_fck”
[ 28.151458] Disabling unused clock “gpt10_fck”
[ 28.155944] Disabling unused clock “dpll4_m6x2_ck”
[ 28.160797] Disabling unused clock “dpll4_m3x2_ck”
[ 28.165618] Disabling unused clock “dpll3_m3x2_ck”
[ 28.170471] Disabling unused clock “sys_clkout1”
[ 28.175170] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
[ 28.189178] registered taskstats version 1
[ 28.195220] twl4030_rtc twl4030_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 28.204162] Waiting 5sec before mounting root device…
[ 28.236938] mmc0: new high speed SD card at address b368
[ 28.242980] mmcblk0: mmc0:b368 SD 970 MiB
[ 28.247680] mmcblk0: p1 p2
[ 33.220062] kjournald starting. Commit interval 5 seconds
[ 33.233428] EXT3 FS on mmcblk0p2, internal journal
[ 33.238311] EXT3-fs: mounted filesystem with ordered data mode.
[ 33.244323] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 33.250579] Freeing init memory: 188K
INIT: version 2.86 booting
Starting udev[ 35.212554] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[ 35.220489] Buffer I/O error on device mtdblock0, logical block 0
[ 35.226837] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 8
[ 35.234710] Buffer I/O error on device mtdblock0, logical block 1
[ 35.240997] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 16
[ 35.248901] Buffer I/O error on device mtdblock0, logical block 2
[ 35.255187] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 24
[ 35.263092] Buffer I/O error on device mtdblock0, logical block 3
[ 36.309722] uncorrectable error : <3>end_request: I/O error, dev mtdblock0, sector 0
[ 36.317565] Buffer I/O error on device mtdblock0, logical block 0
and populating dev cache
Remounting root file system…
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces… eth0: unknown interface: No such device
done.
Wed Jul 1 17:25:00 UTC 2009
INIT: Entering runlevel: 5
Starting syslogd/klogd: done
–Sanjeev
As long as this is the beagleboard, you should replace ttyS0 with ttyS2..
Hi Sanjeev,
You are looking good… the kernel is booting nicely and transfering to usermode which then continues to boot. Not having a video out device shouldn’t matter X will barf and crash. Lets go through the log and point out some things to fix:
First of all your Ethernet USB dongle is being detected properly:
Second the USB OTG is running the CDC Ethernet driver so you could potentially also use that - however, I’ve had some problems getting DHCP to work reliably. The BeagleBoard will by default try and get a DHCP IP address on the OTG port which means your host computer needs to be connected and running dhcpd3 or something similar. Personally for now I would configure the usb0 network interface to use a static IP address (do something similar and compatible on your desktop computer) and then you should be able to SSH on to the BeagleBoard.
Next up, your TWL doesn’t appear to have any battery backup… not a big issue but can cause some headaches if you aren’t running NTP… depends what you are planning to do application wise but this is definiately something to remember and has bitten me a couple of times…
Your NAND memory isn’t initialised. For now it is not important but eventually you might want to look here: http://elinux.org/BeagleBoardNAND on how to both initialise it and then boot using it…
Your other trace actually got further and started unpacking the Angstrom image, started DropBear SSHD etc… I’m going to go read that email and comment on its output as your main problem isn’t any of the stuff mentioned here… but then hopefully this reading will be informative for you :slight_smile:
