[beagleboard] Kernel not booting
Dear all,
I wanted to patch a 2.6.31.5-x5.3 kernel so that I could use LTTng
(Linux Trace Toolkit).
However before patching I wanted to see whether I could actually
compile a kernel using just the linux-source on the board itself.
From the board I downloaded linux-source-2.6.31 using sudo apt-get
install into /usr/src
Then I did:
sudo make clean
sudo make mrproper
I copied the configuration file of the current kernel in /boot to /usr/
src/linux-source-2.6.31/.config
Then I did sudo make menuconfig, and Load Alternate Configuration. I
ensured that the OMAP and BeagleBoard-specific configurations were in
place, and didn't make any changes.
I decided to create a .deb file, so that I could later use rootstock
to get a rootfs and vmlinuz.
So I did:
sudo make-kpkg clean
sudo fakeroot make-kpkg --initrd --append-to-version=-custom
kernel_image kernel_headers
After about 4 hours, I got two .deb packages in /usr/src.
Since rootstock only accepts .deb images with the --kernel-image
parameter that are located at some website (http), I used lighttp and
copied the kernel image .deb to /var/www/kernel_image/, such that the
rootstock command became:
sudo rootstock --fqdn beagleboard --login ubuntu --password temppwd --
imagesize 2G --seed wget --dist karmic --serial ttyS2 --kernel-image
http://192.168.1.100/kernel_image/linux-image-2.6.31.4-custom_2.6.31.4-custom-10.00.Custom_armel.deb
I then ended up with armel-rootfs-201005140928.tgz and a vmlinuz file,
which I copied to the various partitions on another SD Card after
doing mkimage etc. just as I had done for the current working kernel.
However, on switching on the beagle board, it hangs forever at
Starting
kernel ...
Uncompressing
Linux.............................................................
Can any of you please suggest what is going wrong, or an alternative
way of getting a kernel running after compiling from source?
Thanks for your attention,
Gianluca
Could you kindly give me the command to apply the patch-set? I assume
it should be done at the very beginning before make menuconfig..
Gianluca
patch?
patch -p1 < /dir/to/patch
But I think that command applies to files that end as .patch, while on
the http://rcn-ee.net/deb/kernel/beagle/karmic/v2.6.31.5-x5.3/ website
there are only two .diff files. From where could I download the patch
for BeagleBoard for 2.6.31.5?
Gianluca
Bad assumption... patch doesn't care what the extension is.. As long
as it can read it, it'll attempt to patch it..
