[beagleboard] Linux Development
Is there anybody who can suggest any linux developement tools in order to develop application such as visual basic or c# for linux?
What is the suitable IDE for the linux based environment? I want to access to the RS232 Port using the beagleboard and hence i wanna do something with it such as lighting up some led.
This isn't .NET, but if you want to try programming in C, here is a detailed tutorial to doing so with the Eclipse IDE:
http://www.lvr.com/eclipse1.htm
Here is an application for accessing a USB virtual serial port on the BeagleBoard:
http://www.lvr.com/beagleboard.htm
For a true serial port, substitute the port's device node, such as /dev/tty0.
Jan
Thanks. This help a lot :smiley:
