[beagleboard] Not able to boot the BeagleBone with Linux 3.8 kernel
So, have you tried updating u-boot to v2013.01?
Hi Robert,
Thanks for the pointers.
Updated the u-boot to 2012-10. The board booted up.
Vijay
actually I’ll build 2012.10 myself and see what happens… stay tuned…
You know, it sometimes helps to actually follow the wiki directions...
Hint Hint... :wink:
http://pastebin.com/gBLQieWF
You know, it sometimes helps to actually follow the wiki directions…
Hint Hint… :wink:
Robert Nelson
http://www.rcn-ee.com/
I’m pretty sure I followed the directions for rebuilding u-boot to the letter…
I did all three sections of http://www.eewiki.net/display/linuxonarm/BeagleBone at Bootloader.
Like the original poster, I’m trying to build the kernel from Koen Kooi’s directions.
GitHub - beagleboard/kernel at 3.8
So I didn’t really pay attention to the rest of the wiki page
Rebuilding 2012.10 didn’t work either (and the patches of course did not apply very well)
I’ll keep puzzling over this. I must be missing something simple…
Never was too good at following directions though…
A more explicit hint may be needed later…
besides, vijay updated to 2012.10 when you said update to 2013.01…
don’t I get some credit for following directions there? :wink:
Hint Hint... :wink:
U-Boot SPL 2013.01-dirty (Jan 25 2013 - 09:49:12)OMAP SD/MMC: 0reading u-boo - Pastebin.com
Robert Nelson
I'm pretty sure I followed the directions for rebuilding u-boot to the
letter..
Like the original poster, I'm trying to build the kernel from Koen Kooi's
directions.
Please post your "uEnv.txt", Koen has an example at that site...
So I didn't really pay attention to the rest of the wiki page
Rebuilding 2012.10 didn't work either (and the patches of course did not
apply very well)
Well, for v2012.10, there was a different patchset..
They would have applied cleanly...
I'll keep puzzling over this. I must be missing something simple..
Never was too good at following directions though..
A more explicit hint may be needed later...
besides, vijay updated to 2012.10 when you said update to 2013.01..
don't I get some credit for following directions there? :wink:
Please post your “uEnv.txt”, Koen has an example at that site…
I tried his example uEnv.txt… also tried hitting a key and using u-boot at the command prompt, filling in what seemed to be missing environment variables…
I didn’t see anything in uEnv.txt that seemed to relate to the unsupported machine ID. I didn’t think a bad uEnv.txt could even cause that message… My problem is not in u-boot, it is in uEnv.txt? I wasn’t expecting that…
I thought the supported machine IDs were right in u-boot.img.
Anyway, I’m trying to build your version of the kernel now instead. It’s crunching away right now…
Thanks!
Drew
I tried his example uEnv.txt.. also tried hitting a key and using u-boot at
variables..
I didn't see anything in uEnv.txt that seemed to relate to the unsupported
machine ID. I didn't think a bad uEnv.txt could even cause that message...
My problem is not in u-boot, it is in uEnv.txt? I wasn't expecting that...
uEnv.txt just tells the u-boot how to load everything, though there
may be a difference, that could cause the issue..
Heres' mine..
http://eewiki.net/display/linuxonarm/BeagleBone#BeagleBone-uEnv.txtv3.6.xdevicetreebasedbootscript
Anyway, I'm trying to build your version of the kernel now instead. It's
crunching away right now..
It's the exact same patchset to what is in
Just a slight tweak to the defconfig..
same patchset? okay, that’s good to know it isn’t a totally different flavor of beaglebone kernel.
With your uEnv.txt and the zImage I built I get…
(hang)
so now maybe I’ve broken it even more, it doesn’t even get to the machine ID error message?
but that’s okay, I learn by mistakes.
I’m going through the rest of the stuff on your wiki page…
Oh, I’m trying to build a low latency desktop version of the kernel; I did change that one option. I’ll also try a stock build instead.
Drew
Yeah, at this point... Don't change the config's too much as it is
very touchy with very large patchset we have for v3.8-rc5..
okay…
I set
CC=arm-arago-linux-gnueabi-
in my system.sh to match the tools I have installed
It seemed to compile okay for build_kernel.sh
I’ll try switching to the linaro toolchain.
