[beagleboard] Out image cropped on composite video/s-video out
Is this the BeagleBoard or the BeagleBoard-xM?
The regular BeagleBoard.
I found this old post, https://groups.google.com/forum/?fromgroups#!searchin/beagleboard/overscan/beagleboard/KIQXLbhVAEI/jlO312McIVYJ
which made me wonder whether my problem could b solved using the FBIOPUT_VSCREENINFO and OMAPFB_SETUP_PLANE ioctls.
I found out that i could increase the image that gets cropped off from the right by increasing pos_x from the default 0 via OMAPFB_SETUP_PLANE ioctl. which is the opposite of what i want.
I also found that you could loose some data from the left side by limiting the out_width via OMAPFB_SETUP_PLANE. Again not what i wanted.
So far i haveā€™nt found a solution to my problem using these ioctls. Is there any possibility of doing so? or are there other ways to solve this problem?
