[beagleboard] [PATCH v5 2/2] Add support for mt9p031 (LI-5M03 module) in Beagleboard xM.
Subject: Re: [beagleboard] [PATCH v5 2/2] Add support for mt9p031 (LI-5M03 module) in Beagleboard xM.
To: javier.martin@vista-silicon.com
Cc: beagleboard@googlegroups.com, linux-media@vger.kernel.org, g.liakhovetski@gmx.de, laurent.pinchart@ideasonboard.com, mch_kot@yahoo.com.cn, koen@beagleboard.org
Received: Wednesday, 1 June, 2011, 3:04 PM
Hi Javier, Koen,
> Op 1 jun 2011, om 17:36 heeft Javier Martin het
volgende geschreven:
>> New "version" and "vdd_io" flags have been added.
>> A subtle change now prevents camera from being
registered
>> in the wrong platform.
> I get a decent picture now with the following:
> media-ctl -r -l '"mt9p031 2-0048":0->"OMAP3 ISP
CCDC":0[1], "OMAP3 ISP CCDC":1->"OMAP3 ISP CCDC
output":0[1]'
> media-ctl -f '"mt9p031 2-0048":0[SGRBG12 320x240],
"OMAP3 ISP CCDC":0[SGRBG8 320x240], "OMAP3 ISP
CCDC":1[SGRBG8 320x240]'
> yavta-nc --stdout -f SGRBG8 -s 320x240 -n 4
--capture=10000 --skip 3 -F $(media-ctl -e "OMAP3 ISP CCDC
output") | mplayer-bayer - -demuxer rawvideo -rawvideo
w=320:h=240:format=ba81:size=76800 -vo fbdev2 -vf ba81
> 720p also seems to work.
> It is really, really dark though. Is this due to
missing controls or due to the laneshifting?
> regards,
> Koen
I made changes the same as my last post.
Output is MUCH more encouraging now with v6 patch.
# media-ctl -r -l '"mt9p031 2-0048":0->"OMAP3 ISP
output":0[1]'
Resetting all links to inactive
Setting up link 16:0 -> 5:0 [1]
Setting up link 5:1 -> 6:0 [1]
# media-ctl -f '"mt9p031 2-0048":0[SGRBG12 320x240], "OMAP3
ISP CCDC":0[SGRBG8 320x240], "OMAP3 ISP CCDC":1[SGRBG8
320x240]'
Setting up format SGRBG12 320x240 on pad mt9p031 2-0048/0
Format set: SGRBG12 320x240
Setting up format SGRBG12 320x240 on pad OMAP3 ISP CCDC/0
Setting up format SGRBG8 320x240 on pad OMAP3 ISP CCDC/0
Format set: SGRBG8 320x240
Setting up format SGRBG8 320x240 on pad OMAP3 ISP CCDC/1
# yavta --stdout -f SGRBG8 -s 320x240 -n 4 --capture=100
--skip 3 -F `media-ctl -e "OMAP3 ISP CCDC output"` | nc
10.1.1.16 3000
Device /dev/video2 opened.
Device `OMAP3 ISP CCDC output' on `media' is a video
capture device.
Video format set: width: 320 height: 240 buffer size:
76800
Video format: GRBG (47425247) 320x240
4 buffers requested.
length: 76800 offset: 0
Buffer 0 mapped at address 0x40057000.
length: 76800 offset: 77824
Buffer 1 mapped at address 0x400aa000.
length: 76800 offset: 155648
Buffer 2 mapped at address 0x40220000.
length: 76800 offset: 233472
Buffer 3 mapped at address 0x402da000.
0 (0) [-] 4294967295 76800 bytes 457.431406
1306964763.471233 -0.001 fps
Hangs at this point - 'ctrl c'
[ 464.115386] omap3isp omap3isp: CCDC stop timeout!
[ 465.125488] omap3isp omap3isp: Unable to stop OMAP3
ISP CCDC
I can look at the frame - looks like noise on the left hand
side only.
Now producing:
e=100 --skip 3 -F `media-ctl -e "OMAP3 ISP CCDC output"` | nc 10.1.1.16 3000
Device `OMAP3 ISP CCDC output' on `media' is a video capture device.
Video format set: width: 320 height: 240 buffer size: 76800
Buffer 0 mapped at address 0x40209000.
Buffer 1 mapped at address 0x402a4000.
Buffer 2 mapped at address 0x40305000.
Buffer 3 mapped at address 0x4033d000.
0 (0) [-] 4294967295 76800 bytes 161.364596 1306972315.470868 -0.001 fps
1 (1) [-] 4294967295 76800 bytes 161.847217 1306972315.953520 2.072 fps
2 (2) [-] 4294967295 76800 bytes 162.081111 1306972316.187383 4.275 fps
3 (3) [-] 4294967295 76800 bytes 162.314970 1306972316.421212 4.276 fps
4 (0) [-] 4294967295 76800 bytes 162.548792 1306972316.655095 4.277 fps
5 (1) [-] 4294967295 76800 bytes 162.782648 1306972316.888951 4.276 fps
6 (2) [-] 4294967295 76800 bytes 163.016504 1306972317.122807 4.276 fps
7 (3) [-] 4294967295 76800 bytes 163.250330 1306972317.356633 4.277 fps
8 (0) [-] 4294967295 76800 bytes 163.484186 1306972317.590489 4.276 fps
9 (1) [-] 4294967295 76800 bytes 163.718012 1306972317.824345 4.277 fps
10 (2) [-] 4294967295 76800 bytes 163.951868 1306972318.058171 4.276 fps
11 (3) [-] 4294967295 76800 bytes 164.185694 1306972318.291997 4.277 fps
12 (0) [-] 4294967295 76800 bytes 164.419550 1306972318.525883 4.276 fps
13 (1) [-] 4294967295 76800 bytes 164.653406 1306972318.759709 4.276 fps
Changed mt9p031.c:
#define MT9P031_EXTCLK_FREQ 12000000
I was digging around and found an Aptina driver for 2.6.32:
https://github.com/Aptina/BeagleBoard-xM/blob/master/MT9P031/Angstrom/mt9p031.c
They set it to 12000000 or 24000000 depending.
Mine is very washed out.. opposite to what Koen has observed.
Chris
