[beagleboard] Problem with Angstrom on beagleboard
Greetings,
I’m trying to install the 2.6.28 Kernel version of Angstrom OE on my C4 beagleboard. When I put the kernel on the SD card and run it on the bb, the board doesn’t boot properly. When I read the booting messages throught CuteCom I get the following
U-Boot 2010.03-rcl (Mar 30 2010 - 13:46:26)
OMAP3530-GP ES3.1, CPU-OPP2, L3-165MHZ, Max clock-720Mhz
I2C: ready
the xloader version is 1.4.2
Do you have any idea what this problem could be? And how can I get over this?
Majid
I ran into the same problem what i did was just delete the u-boot.bin. not sure if that was the right thing but it worked for me
Dave
This is common problem.. You need X-loader 1.4.4ss when using 2010.03-rc1...
