[beagleboard] Project based on BeagleBoard
start from gstreamer. You can transmit video over udpsink or tcp.
Google it as gstreamer video stream.
Regards
2012/12/24 Nag <sainathbliss@gmail.com>
Be careful of UDP if you move from WiFI to cellular. Multicast UDP is
often blocked to the device, and UDP is sometimes blocked (AT&T,
Sprint).
You are boxed into TCP with push notifications by the carriers who
perform the blocking.
Jeff
