I haven't actually written the Ubuntu image to eMMC yet (I have on the first
five BBB's but not on the sixth, I can't get past step 1 on the sixth).
This is my goal.
1. Get Ubuntu installed on a microSD card.
2. Configure the BBB to boot from the microSD WITHOUT pressing the boot
button every time it boots.
I really don't care what version of Linux is in the eMMC, I just want the
BBB to automatically boot from the microSD card. The BBB will be accessed
and rebooted remotely, without a human present to push the button.
Well, that's been the default setting for a long time with those image
i just posted a link to.. Just grab the "eMMC-flasher" first to update
the eMMC. Then any of the "microSD" card images will boot just fine
without pushing the boot button...
Then I inserted the card in the BBB, held down the boot button while powering up, and it booted from the card. If I reboot, it boots from the microSD card, which is what I want. If I remove the card and power up, it boots from the eMMC.
Do I need to flash anything to the eMMC? The eMMC still has the default Debian. Since the BBB boots from the card as desired, maybe I don’t need to do anything to the eMMC.
I have one question. I will be using a XBee cape board that needs UART2 to be enabled. I will need to add a line like this to uEnv.txt:
optargs=capemgr.enable_partno=BB-UART2
I think I should add this line /boot/uboot/uEnv.txt in the eMMC, am I right?
I ask this because the microSD card has two copies, /uEnv.txt and /boot/uEnv.txt. The contents of these two files and the file in eMMC are different.
I installed Ubuntu (not Debian), by following your instructions for copying
the raw microSD image to the microSD card: BeagleBoardUbuntu - eLinux.org
Debian. Since the BBB boots from the card as desired, maybe I don't need to
Okay, out of the box, that image shipped with 3.14.x, so you need to
downgrade to 3.8.x to use "capemgr.enable_partno=BB-UART2"
cd /opt/scripts/tools/
git pull
sudo ./update_kernel.sh --stable --bone-channel
Only edit /boot/uEnv.txt
cape_enable=capemgr.enable_partno=BB-UART2
different.
So /boot/uEnv.txt is the main script, /uEnv.txt is just there for
compatibility with old eMMC's..
If you look at /uEnv.txt closely, it reads /boot/uEnv.txt...
In your last post you suggested downgrading to 3.8.x so that I can use the capemgr to enable the BB-UART2-00A0.dtbo device tree overlay. But before I downgrade, is there an alternative way to enable UART2 that will work with 3.14.X?
I’m using an XBee cape board that needs UART2 enabled. Whatever method I use to enable UART2, it must work automatically at boot time so that my cape board works after booting without intervention from me.
By the way, I noticed that /dev/ttyO2 is present on my 3.14.X image, so I tried simply plugging in my cape board to see if UART2 worked, but no luck.
