[beagleboard] Re: Booting BB xM over Ethernet
I recently encountered this EHCI error when my network setup was wrong. I noticed it when I was connecting the BBxM directly to my computer, which was running a virtual machine. When the VM network configuration was wrong, I saw some EHCI timeout errors. The physical link was OK, but the virtual link (IP addresses) were wrong. From what I recall, if the target (u-boot) can’t reach the host at the correct address, I saw these errors. The solution was to make sure that the network configuration was correct.
So, start with ping - get that to work properly. Then TFTP the kernel. If you can get both of those working, then you should be able to get NFS running.
John
