[beagleboard] Re: DVI connector
Yes ok…now i am ready to buy an new nonitor with the DVI slot…i have an another doubt…whether all DVI supported monitor will have the support of DVI-D support?or we have to buy seperate monitor which have only DVI-D?
Because there is lots of different DVI connectors(DVI-I,DVI-A,DVI-D)…whether all monitor with DVI supports all the DVI types or it has seperate monitors?
— On Tue, 10/3/09, Vladimir Pantelic pan@nt.tu-darmstadt.de wrote:
> From: Vladimir Pantelic pan@nt.tu-darmstadt.de
> Subject: [beagleboard] Re: DVI connector
> To: beagleboard@googlegroups.com
> Date: Tuesday, 10 March, 2009, 11:12 PM
> Brian Phelps wrote:
> > composite: there is S-Video out, so there is also composite.
> > VGA: on “large legacy system”: just buy an off-the-shelf DVI to VGA.
> > The problem is the recommended HD-Fury supposedly damaged a BB. So that
> > was my solution.
> still most BB hackers probably just connect a monitor, for the few that do not have a DVI capable (yet) the easiest way
> is to just get one, they do not cost that much any more.
> > > Also no it would not cost more than the BB. I could do a run of
> > > something like this for under $40. Thats not including connectors
> > > though. It might cost that much if you got them made in Germany :slight_smile:
> > I pay you in beer, OK? :slight_smile:
> > Yummy, I prefer Belgian though
> sorry, no deal :frowning:
> Add more friends to your messenger and enjoy! Invite them now.
DVI is DVID + DVIA
DVI-D is only the digital portion
I don’t hink I have ever seen a DVI-A only monitor.
There is alos a dual link DVI with two channels. We only support single channel.
Because there is lots of different DVI connectors(DVI-I,DVI-A,DVI-D)…whether all monitor with DVI supports all the DVI types or it has seperate monitors? |
DVI-D: Pure digital signal on digital pins;
DVI-A: Pure analog VGA on the analog Pins
DVI-I: Both are supported
The wikipedia article is very helpful on this. Check it out.
