[beagleboard] Re: How to enable RTC for beagle board
How to test this RTC in u-boot level? Is there any commands for this RTC?
Sanjeev
I do not know the answer to the u-boot question. I would suggest
looking at the u-boot source code and documentation, which is what I
would do, and I will probably end up doing at some point because I am
having an issue with an external RTC under one configuration.
Once you are up and running Linux, you can use hwclock to examine and
set the RTC.
"hwclock --help" gives usage information
-Preston
Preston Wilson said the following on 04/20/2009 07:07 AM:
