I formated SD card with twp partion (LABEL1 and LABEL2), I copied mlo,
u-boot.bin and uImage( Built using map3530beagel_defconfig) to LABEL1. In LABEL2 i untared
Angstrom-Beagleboard-demo-image-glibc-ipk-2009.X-test-20090326-beagleboard.rootfs.tar.bz2
file and i booted and it is stoping at RTC level, here is the log.
1414432 bytes read
## Booting kernel from Legacy Image at 80300000 …
Image Name: Linux-2.6.22.18-omap3
Data Size: 1414368 Bytes = 1.3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
<5>Linux version 2.6.22.18-omap3 (root@INETFI-LINUX-MC4) (gcc version 4.2.1 (CodeSourcery Sourcery G++ Lite 2007q3-51)) #8 Mon Jun 29 21:32:35 9
CPU: ARMv7 Processor [411fc082] revision 2 (ARMv7), cr=00c5387f
Machine: OMAP3 Beagle board
Memory policy: ECC disabled, Data cache writeback
<7>On node 0 totalpages: 32768
<7> DMA zone: 256 pages used for memmap
<7> DMA zone: 0 pages reserved
<7> DMA zone: 32512 pages, LIFO batch:7
<7> Normal zone: 0 pages used for memmap
<6>OMAP3430ES1
<6>SRAM: Mapped pa 0x40200000 to va 0xd7000000 size: 0x100000
CPU0: D VIPT write-through cache
CPU0: cache: 768 bytes, associativity 1, 8 byte lines, 64 sets
Built 1 zonelists. Total pages: 32512
<5>Kernel command line: console=ttyS0,115200n8 mem=128M noinitrd rw root=/dev/mmcblk0p2 rootdelay=5 rootfstype=ext3
<6>GPMC revision 5.0
<6>IRQ: Found an INTC at 0xd8200000 (revision 4.0) with 96 interrupts
<6>Total of 96 interrupts on 1 active controller
<6>OMAP34xx GPIO hardware version 2.5
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
<6>Memory: 128MB = 128MB total
<5>Memory: 126720KB available (2688K code, 378K data, 108K init)
<7>Calibrating delay loop… 499.92 BogoMIPS (lpj=1949696)
Mount-cache hash table entries: 512
<6>CPU: Testing write buffer coherency: ok
<3>twl4030: I2C Client[3] is not initialized[515]
<3>twl4030: I2C Client[3] is not initialized[464]
<6>SmartReflex driver initialized
<6>OMAP DMA hardware revision 4.0
<6>OMAP Display hardware version 2.0
<6>i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
<6>i2c_omap i2c_omap.2: bus 2 rev3.12 at 100 kHz
<6>i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
<6>TWL4030: TRY attach Slave TWL4030-ID0 on Adapter OMAP I2C adapter [1]
<6>TWL4030: TRY attach Slave TWL4030-ID1 on Adapter OMAP I2C adapter [1]
<6>TWL4030: TRY attach Slave TWL4030-ID2 on Adapter OMAP I2C adapter [1]
<6>TWL4030: TRY attach Slave TWL4030-ID3 on Adapter OMAP I2C adapter [1]
<6>TWL4030 Power Companion Active
<6><6>TWL4030: Driver registration complete.
<6>TWL4030 GPIO Demux: IRQ Range 376 to 386, Initialization Success
<6>Initialized TWL4030 USB module<5>SCSI subsystem initialized
<6>usbcore: registered new interface driver usbfs
<6>usbcore: registered new interface driver hub
<6>usbcore: registered new device driver usb
<6>musb_hdrc: version 2.2a/db-0.5.2, pio, otg (peripheral+host), debug=0
<7>musb_hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine (X), bulk split (X), HB-ISO Rx (X), HB-ISO Tx (X), SoftConn)
<7>musb_hdrc: MHDRC RTL version 1.400
<7>musb_hdrc: setup fifo_mode 4
<7>musb_hdrc: 29/31 max ep, 15424/16384 memory
<7>musb_hdrc: hw_ep 0shared, max 64
<7>musb_hdrc: hw_ep 1tx, max 512
<7>musb_hdrc: hw_ep 1rx, max 512
<7>musb_hdrc: hw_ep 2tx, max 512
<7>musb_hdrc: hw_ep 2rx, max 512
<7>musb_hdrc: hw_ep 3tx, max 512
<7>musb_hdrc: hw_ep 3rx, max 512
<7>musb_hdrc: hw_ep 4tx, max 512
<7>musb_hdrc: hw_ep 4rx, max 512
<7>musb_hdrc: hw_ep 5tx, max 512
<7>musb_hdrc: hw_ep 5rx, max 512
<7>musb_hdrc: hw_ep 6tx, max 512
<7>musb_hdrc: hw_ep 6rx, max 512
<7>musb_hdrc: hw_ep 7tx, max 512
<7>musb_hdrc: hw_ep 7rx, max 512
<7>musb_hdrc: hw_ep 8tx, max 512
<7>musb_hdrc: hw_ep 8rx, max 512
<7>musb_hdrc: hw_ep 9tx, max 512
<7>musb_hdrc: hw_ep 9rx, max 512
<7>musb_hdrc: hw_ep 10tx, max 512
<7>musb_hdrc: hw_ep 10rx, max 512
<7>musb_hdrc: hw_ep 11tx, max 512
<7>musb_hdrc: hw_ep 11rx, max 512
<7>musb_hdrc: hw_ep 12tx, max 512
<7>musb_hdrc: hw_ep 12rx, max 512
<7>musb_hdrc: hw_ep 13tx, max 512
<7>musb_hdrc: hw_ep 13rx, max 512
<7>musb_hdrc: hw_ep 14shared, max 1024
<7>musb_hdrc: hw_ep 15shared, max 1024
<6>musb_hdrc: USB OTG mode controller at c8800000 using PIO, IRQ 92
<6>Time: 32k_counter clocksource has been installed.
<6>Switched to high resolution mode on CPU 0
<3>Power Management for TI OMAP.
<6>cpuidle: using driver omap3_idle
<3>create_proc_entry succeeded
<4>NetWinder Floating Point Emulator V0.97 (double precision)
<5>VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
<6>JFFS2 version 2.2. (NAND) �Щ 2001-2006 Red Hat, Inc.
<6>io scheduler noop registered
<6>io scheduler anticipatory registered (default)
<6>io scheduler deadline registered
<6>io scheduler cfq registered
<7>omap2_disp_outLCD panel 1024x768
<4>timeout waiting for frame-done interrupt
<7>omap2_disp_outTV 640x480 interlaced
<6>omap24xxfb: Options “”
Console: switching to colour frame buffer device 128x48
<6>omap24xxfb: fb0 frame buffer device
<6>omap24xxfb: display mode 1024x768x16 hsync 22kHz vsync 28Hz<6>omap_rng omap_rng: OMAP Random Number Generator ver. 70
<6>OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
<6>serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
Linux version 2.6.22.18-omap3 (root@INETFI-LINUX-MC4) (gcc version 4.2.1 (CodeSourcery Sourcery G++ Lite 2007q3-51)) #8 Mon Jun 29 21:32:35 IST9
OMAP3430ES1
GPMC revision 5.0
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
<6>serial8250.0: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
<6>serial8250.0: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
<6>loop: module loaded
loop: module loaded
<6>OMAP RTC Driver
OMAP RTC Driver
<4>omap-twl4030rtc:TWL4030-RTC Power up reset detected.
<6>omap-twl4030rtc:Enabling TWL4030-RTC.
<6>Linux video capture interface: v2.00
<6>omap24xxvout: registered device video1 [v4l2]
<6>omap24xxvout: registered device video2 [v4l2]
<6>sn9c102: V4L2 driver for SN9C1xx PC Camera Controllers v1:1.47pre49
<6>usbcore: registered new interface driver sn9c102
<6>i2c /dev entries driver
<6>omap2-nand driver initializing
<6>NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
<5>Creating 5 MTD partitions on “omap2-nand.0”:
<5>0x00000000-0x00080000 : “X-Loader-NAND”
<5>0x00080000-0x00260000 : “U-Boot-NAND”
<5>0x00260000-0x00280000 : “Boot Env-NAND”
<5>0x00280000-0x00780000 : “Kernel-NAND”
<5>0x00780000-0x10000000 : “File System - NAND”
<5>usbmon: debugfs is not available
<6>usbcore: registered new interface driver cdc_acm
<6>drivers/usb/class/cdc-acm.c: v0.25:USB Abstract Control Model driver for USB modems and ISDN adapters
<6>Initializing USB Mass Storage driver…
<6>usbcore: registered new interface driver usb-storage
<6>USB Mass Storage support registered.
<6>zero gadget: Gadget Zero, version: St Patrick’s Day 2004
<6>zero gadget: using musb_hdrc, OUT ep1out IN ep1in
<6>musb_hdrc musb_hdrc.0: MUSB HDRC host driver
<6>musb_hdrc musb_hdrc.0: new USB bus registered, assigned bus number 1
<6>usb usb1: configuration #1 chosen from 1 choice
<6>hub 1-0:1.0: USB hub found
<6>hub 1-0:1.0: 1 port detected
<6>mice: PS/2 mouse device common for all mice
<6>usbcore: registered new interface driver usbhid
<6>drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
<6>Advanced Linux Sound Architecture Driver Version 1.0.14 (Thu May 31 09:03:25 2007 UTC).
<6>OMAP3430 TWL4030 Audio Support: OMAP3430 TWL4030 Audio Support: Chip Rev[0x2f] Initialized
<6>audio support initialized
<6>usbcore: registered new interface driver snd-usb-audio
<6>ALSA device list:
ALSA device list:
<6> #0: TWL4030
#0: TWL4030
<6>VFP support v0.3: VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
<6>cpuidle: using governor menu
<6>Waiting 5sec before mounting root device…
<4>mmc0: host does not support reading read-only switch. assuming write-enable.
<6>mmcblk0: mmc0:0007 SD02G 1955840KiB
<6> mmcblk0: mmcblk0: p1 p1 p2 p2
<7>CEATA Card Not Found
<6>mmcblk1: mmc1:0001 MMC02G 1976320KiB
<6> mmcblk1: mmcblk1:
<6>kjournald starting. Commit interval 5 seconds
<4>EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
<6>EXT3 FS on mmcblk0p2, EXT3 FS on mmcblk0p2, internal journal
internal journal
<6>EXT3-fs: mounted filesystem with ordered data mode.
VFS: Mounted root (ext3 filesystem).
<6>Freeing init memory: 108K
INIT: version 2.86 booting
Starting udev/etc/rcS.d/S03udev: line 56: can’t create /proc/sys/kernel/hotplug: nonexistent directory
Remounting root file system…
WARNING: Couldn’t open directory /lib/modules/2.6.22.18-omap3: No such file or directory
FATAL: Could not open /lib/modules/2.6.22.18-omap3/modules.dep.temp for writing: No such file or directory
Unknown HZ value! (94) Assume 100.
error: “net.ipv4.conf.default.rp_filter” is an unknown key
error: “net.ipv4.conf.all.rp_filter” is an unknown key
ALSA: Restoring mixer settings…
/usr/sbin/alsactl: load_state:1616: No soundcards found…
Configuring network interfaces… No usable address families found.
socket: No such file or directory
socket: Function not implemented
done.
Starting portmap daemon: portmapportmap: fork: No such device.
hwclock: can’t open ‘/dev/misc/rtc’: No such file or directory
Fri Jun 12 13:04:00 BST 2009
Please let me the exact issue with this.
What exactly this error meanse?
–Sanjeev
The error means that the kernel couldn’t find its modules directory and needed to load a module for some reason. Normally you could just download the relevant “modules-” archive file from here: http://www.angstrom-distribution.org/demo/beagleboard/ and then extract it over the top of your Angstrom parition.
However, your kernel is a little old (2.6.22 is two years old) and there isn’t an appropriate modules archive for that version. I would upgrade your kernel to 2.6.29 as this includes a lot of OMAP related fixes. You can get that from the same link above…
