Your not getting a response because u wiped out the nand as gerald said goto the beagleboard ubuntu wiki the prebuilt image is there I found 10.04 easiest to install download it change directory mine was Downloads do a sudo tar xf to the file then cd into the extracted folder that was made ubuntu-armel.....just to be safe use the command listed for your board on the wiki to invoke the script just change sdx to the appropriate drive I find it easiet to just completely erase and use the raw sd hop this helps
