[beagleboard] Re: qt-embedded using OE
Thanks. I was able to finish the build of qt-embedded. I did have another qt related problem when I tried to ‘bitbake qtopia-core-console-image’. The compile failed building some of the native moc tools (see message below). I’m building on opensuse 11.0 and have been able to build qtopia-core for other platforms in this environment.
I’m new to OE and bitbake so I’m not sure what the problem could be.
Any help is deeply appreciated.
In file included from …/…/include/QtCore/qstring.h:1,
from …/…/include/QtCore/…/…/src/corelib/kernel/qobject.h:43,
from …/…/include/QtCore/qobject.h:1,
from …/…/include/QtCore/…/…/src/corelib/io/qiodevice.h:41,
from …/…/include/QtCore/qiodevice.h:1,
from io/qbuffer.h:40,
from io/qbuffer.cpp:37:
…/…/include/QtCore/…/…/src/corelib/tools/qstring.h:787: warning: type qualifiers ignored on function return type
…/…/include/QtCore/…/…/src/corelib/tools/qstring.h:788: warning: type qualifiers ignored on function return type
…/…/include/QtCore/…/…/src/corelib/tools/qstring.h:789: warning: type qualifiers ignored on function return type
…/…/include/QtCore/…/…/src/corelib/tools/qstring.h:795: warning: type qualifiers ignored on function return type
…/…/include/QtCore/…/…/src/corelib/tools/qstring.h:796: warning: type qualifiers ignored on function return type
In file included from io/qbuffer.cpp:445:
.moc/release-shared-emb-arm/moc_qbuffer.cpp:20: error: expected constructor, destructor, or type conversion before ‘static’
.moc/release-shared-emb-arm/moc_qbuffer.cpp:42: error: ‘qt_meta_data_QBuffer’ was not declared in this scope
.moc/release-shared-emb-arm/moc_qbuffer.cpp:71: error: expected constructor, destructor, or type conversion at end of input
make[1]: *** [.obj/release-shared-emb-arm/qbuffer.o] Error 1
make[1]: Leaving directory `/home/dlamborg/oe/tmp/work/armv7a-angstrom-linux-gnueabi/qtopia-core-4.3.3-r3/qtopia-core-opensource-src-4.3.3/src/corelib’
make: *** [sub-corelib-make_default-ordered] Error 2
FATAL: oe_runmake failed
— On Wed, 5/13/09, Favor Tang tangher@gmail.com wrote:
> From: Favor Tang tangher@gmail.com
> Subject: [beagleboard] Re: qt-embedded using OE
> To: beagleboard@googlegroups.com
> Date: Wednesday, May 13, 2009, 9:29 PM
> hi.
> this is the error about md5sum dont match your package. maybe your
> package is broken due to the network problem when downloading. And
> make sure that md5sum matches with your download package, please see
> this:
> http://www.nabble.com/md5sum-error-with-bitbake-td18046171.html
> I suggest you download this package manually, and see what the md5sum
> is, if the md5sum match with the required checksum by OE, then you
> should copy this package to OE download directory. after that, just
> run bitbake again.
> thanks
