I just wanted to throw this out for contemplation. I have sent this
to DigiKey as well.
If I were to have a wish list for Beagleboard Out-of-Box-Experience
(OOBE) improvement, it would be one item: Digikey should offer a
"Rest of What You Need Kit" (RoWYNK) that would include the below.
- HDMI-A/Male to DVI-D/Female Adapter -- so you can plug your
monitor into Beagle. AE10254-ND
- USB-Standard-A/Female to USB-Mini-A/Male -- so you can plug in
USB peripherals. *
- DB9/Male to IDC10/Female Adapter -- so you can plug in console
terminal. *
- USB-Standard-A/Male to Dual-PS2/Female Adapter -- so you can
plug in Keyboard and Mouse. *
- 5 VDC Power Supply -- so you can turn the board on. T450-P5P-ND
- DB9F to DB9F Null Modem RS-232 Cable -- so you can plug console
into laptop. AE9879-ND
- USB SD Card Reader -- so you can make SD Cards. DA-70310-ND
- A starter pack (maybe 2) 2GB SD Cards. 585-1226-ND
- A pre-programmed SD Card with Angstrom Demo ready to boot. *
* Not currently available from DigiKey.
There are other ways to do this, but this setup allows you to use
things you already have -- e.g. a Monitor with a DVI-D Cable, and
Standard USB Peripherals. Unpack Beagle. Unpack RoWYNK. Plug in
cables. Plug in SD card. Turn on power. And away you go.
I’m planning to offer a kit just as you are proposing, including acrylic case. It would be even better if I’m allowed to buy the DigiKey board in bulk so I can offer fully assembed kits. Unfortunately, the current DigiKey business model prevents this, so we’ill have to wait until we have other board vendors that is more open. The best I can do right now is to have my customers ship me their BeagleBoard in order to get fully assembled kits.
to DigiKey as well.
“Rest of What You Need Kit” (RoWYNK) that would include the below.
Of the list of items below, I really only think the following are necessary
HDMI-A/Male to DVI-D/Female Adapter – so you can plug your
USB-Standard-A/Female to USB-Mini-A/Male – so you can plug in
USB peripherals. *
DB9/Male to IDC10/Female Adapter – so you can plug in console
terminal. *
5 VDC Power Supply – so you can turn the board on. T450-P5P-ND
DB9F to DB9F Null Modem RS-232 Cable – so you can plug console
I just discovered an interesting "money saver" for those willing to
connect wires...
If you have a 5V DC Power Supply, then rather than buying the supply
itself from Digikey, you could buy the barrel connector pig tail from
Digikey (for $1.75 instead of $16). The Pigtail part number is
CP-2185-ND at Digikey and it is for the 5.5mm (OD) x 2.1mm (ID) type M
Barrel from CUI.
Add 4 standoffs and nuts, too. Or were those supposed to come with
the board
It was not completely clear what you did and did no get - Its a bare-bones
board. Certainly DigiKey could update the page that they dedicate to BB and
give a shopping list.
I would expect them to leave off the pre-loaded SD Card as this could
be and exercise left
to the reader.
I've posted a shopping list that does include the spacers and
standoffs and a case (all from specialcomp). Take a look at http://code.google.com/p/beagleboard/wiki/BeagleBoardShoppingList for
a more complete list of things that you might like to go with your BB.
