Trying to get s-video to work in Ubuntu 12.10 with bbxm.c1.
The setup worked with Angstrom and with a DVI-D monitor with ubuntu.
However, when I change it to s-video output with uEnv.txt and reboot (in
Ubuntu) the screen shows start/boot-up text, but then just before the GIU
loads, it goes black/blank.cat /proc/cmdline
console=ttyO2,115200n8 console=tty0 vram=12MB omapfb.mode=tv:pal
omapdss.def_disp=tv root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc
buddy=none buddy2=none camera=none wl12xx_clk=my start-up log (http://pastebin.com/TwUyfxAb) and Xorg.0.log
(http://pastebin.com/GaZK6vsL)
Odd, nothing obvious in the logs, anything in xorg.conf? (although
ubuntu might not use that anymore)
ubuntu@arm:~$ cat /var/log/Xorg.0.log | grep omapfb
[ 23.480] Kernel command line: console=ttyO2,115200n8 console=tty0
vram=12MB [01;31m [Komapfb [m [K.mode=tv:1280x720MR-16@60
[ 23.580] (==) Matched [01;31m [Komapfb [m [K as autoconfigured driver 0
[ 23.581] (II) LoadModule: " [01;31m [Komapfb [m [K"
[ 23.587] (WW) Warning, couldn't open module [01;31m [Komapfb [m [K
[ 23.587] (II) UnloadModule: " [01;31m [Komapfb [m [K"
[ 23.587] (II) Unloading [01;31m [Komapfb [m [K
[ 23.587] (EE) Failed to load module " [01;31m [Komapfb [m [K" (module
does not exist, 0)
[ 23.604] (==) Matched [01;31m [Komapfb [m [K as autoconfigured driver 0
[ 23.604] (II) LoadModule: " [01;31m [Komapfb [m [K"
[ 23.607] (WW) Warning, couldn't open module [01;31m [Komapfb [m [K
[ 23.607] (II) UnloadModule: " [01;31m [Komapfb [m [K"
[ 23.607] (II) Unloading [01;31m [Komapfb [m [K
[ 23.607] (EE) Failed to load module " [01;31m [Komapfb [m [K" (module
does not exist, 0)
[ 23.643] (II) FBDEV(0): hardware: [01;31m [Komapfb [m [K (video memory:
808kB)
ubuntu@arm:~$ sudo apt-get install xserver-xorg-video-omap3 et install
E: Unable to locate package xserver-xorg-video-omap3
Do not bother with this package, it's been un-maintained for awhile,
there is a replacement but we haven't defaulted to omapdrm yet to
utilize the replacement.
