Beagleboard SD read speed
I was looking at SD read speed today and got this result:
root@beagleboard:~# hdparm -t /dev/mmcblk0
/dev/mmcblk0:
Timing buffered disk reads: 44 MB in 3.02 seconds = 14.59 MB/sec
That used to be only 5MB/s
The patch that gave the boost was:
http://sakoman.net/cgi-bin/gitweb.cgi?p=linux-omap-2.6.git;a=commitdiff;h=6c4d34031c80ca4b50ffe73a4ef7fe197a760a60
regards,
Koen
Whats the make/capacity of the SD card you are using ?
/dev/mmcblk0:
Very nice. You can do ~12MB/s on N810 in same mode. I wonder if 8 bit mmc mode could make that faster on Beagle or if those 14.5MB are limited by current omap3 clock speed and kernel mmc stack (since even 4 bit over 48MHz should do better in theory).
Frantisek
sandisk 4GB UltraII sdhc.
