Beagleboard standoff specificatons
Hello.
Before using my beagleboard, I wish to protect the bottom side of the
PCB by mounting standoffs.
Are there any mechanical specifications that the standoff kit must
conform to for mounting on the board?
I did not find this in Sec:5.18 of the Rev B5 reference manual.
Best regards,
SS
There are no specific specifications as the components on the back are very small and not that many. A quarter inch should be sufficient for a standoff.
I use quarter inch nylon standoffs in my acrylic cases.
Anything thinner would require trimming of a few tabs off connectors.
Bill Mar
Special Computing
Shobhraj Singh wrote:
Hello.
I used an ordinary, (#5?) standoff I found in my junk box. :slight_smile:
Mine were aluminum, but if you are really concerned then use nylon ones.
Initially I was worried about mechanical clearance with some components near the
holes, but Gerald did us right--- if you are careful during tightening, there is
plenty of room.
b.g.
Hello.
Specifically, they were Mouser P/N 534-1797D: HEX .156x.375 ALUM. 9.53mm long,
3.96mm o.d..
b.g.
