Hi Thomas
In the last couple of days I've tried to set up Ubuntu 12.10 HF following
the instructions on [1]. While most things work as expected, I haven't had
any success in setting up a somewhat accelerated Xserver. All I get is X on
the framebuffer.
Here's what I've tried:
a) I've installed xserver-xorg-video-omap (Here's where the confusion
starts: Is that the neon accelerated one? Wasn't that
xserver-xorg-video-omap3 in previous releases? See below...)
This old neon driver is bitrotten/no longer usable, and the plan is
to replace it with, Rob Clark's xf86-video-omap...
http://cgit.freedesktop.org/xorg/driver/xf86-video-omap/
b) I've built and installed the sgx modules (once again following [1])
The "sgx" ddx is too old (abi wise) to be usable in ubuntu... *side
note, with the new release of "4.08.00.01" i'm playing around with
re-doing an "ubuntu natty" sgx image, althought it's now EOL, the xorg
abi's match.. However nothing is public yet.
c) I've run the provided script "ti-omapdrm.sh" successfully and the result
shows up in Xorg.0.log:
This fails, as it requires the kernel to be built with
"CONFIG_DRM_OMAP" support, which i just haven't thrown the switch yet
to enable by default in v3.6.x..
[ 25.498] (II) LoadModule: "omap"
[ 25.512] (II) Loading /usr/lib/xorg/modules/drivers/omap_drv.so
[ 25.550] (II) Module omap: vendor="X.Org Foundation"
[ 25.550] compiled for 1.13.0, module version = 0.83.0
[ 25.550] Module class: X.Org Video Driver
[ 25.550] ABI class: X.Org Video Driver, version 13.0
[ 25.550] (II) OMAP: Driver for TI OMAP: OMAP3430 with PowerVR SGX530,
OMAP3630 with PowerVR SGX530, OMAP4430 with PowerVR SGX540,
OMAP4460 with PowerVR SGX540, OMAP5430 with PowerVR SGX544 MP,
OMAP5432 with PowerVR SGX544 MP
[ 25.551] (++) using VT number 7[ 25.568] (WW) Falling back to old probe method for omap
[ 28.238] (EE) No devices detected.
[ 28.239] (==) Matched omapfb as autoconfigured driver 0
[ 28.239] (==) Matched modesetting as autoconfigured driver 1
[ 28.239] (==) Matched fbdev as autoconfigured driver 2
[ 28.239] (==) Assigned the driver to the xf86ConfigLayout
[ 28.239] (II) LoadModule: "omapfb"
[ 28.251] (WW) Warning, couldn't open module omapfb
[ 28.251] (II) UnloadModule: "omapfb"
[ 28.251] (II) Unloading omapfb
[ 28.251] (EE) Failed to load module "omapfb" (module does not exist, 0)
[ 28.251] (II) LoadModule: "modesetting"
[ 28.253] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 28.260] (II) Module modesetting: vendor="X.Org Foundation"
[ 28.260] compiled for 1.13.0, module version = 0.5.0
[ 28.260] Module class: X.Org Video Driver
[ 28.260] ABI class: X.Org Video Driver, version 13.0
[ 28.260] (II) LoadModule: "fbdev"
[ 28.262] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 28.283] (II) Module fbdev: vendor="X.Org Foundation"
[ 28.284] compiled for 1.12.99.902, module version = 0.4.3
[ 28.284] Module class: X.Org Video Driver
[ 28.284] ABI class: X.Org Video Driver, version 13.0
[ 28.284] (II) OMAP: Driver for TI OMAP: OMAP3430 with PowerVR SGX530,
[ 28.285] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 28.285] (II) FBDEV: driver for framebuffer: fbdev
[ 28.285] (++) using VT number 7
(...)[ 28.251] (EE) Failed to load module "omapfb" (module does not exist, 0)
isn't surprising - there's no such thing as omapfb.so anywhere in /usrSearching for hints, I've come across [2], however, trying to install the
deb-package provided there results in an error:dpkg: dependency problems prevent configuration of xserver-xorg-video-omap3:
xserver-xorg-video-omap3 depends on xorg-video-abi-12; however:
Package xorg-video-abi-12 is not installed.
It's dead, should be removed from the archive...
So it appears that the new version of X doesn't support that neon
accelerated driver. Next I tried to compile the code from [2] natively,
however, the build fails. I don't know where to go from here (belonging to
the Joe User category rather than being a hardcore developer, I think I've
tried all the straightforward options). Any ideas on how to go on would be
appreciated.
I'd recommend for a "right now" for Joe User, use the default
framebuffer as is. The recent "ti-omapdrm.sh" script push is just a
sign that i'm starting to get the ducks in the row in the git repo.
(as i use that same repo when testing)... But "today" it's not
ready...
