[beagleboard] Ubuntu on Beagle Bone Black
Check your SD card to be sure there is a uenv.txt file in the boot partition. I have seen the file not get changed from uenv-BBB.txt which leads to this problem.
I have bbb-uEnv.txt, if that is the right one do I just change the name?
Yes, that’s the right one. Rename it to uEnv.txt.
I changed the file name but I still get the 2 LED.
I tried it a second time and it worked. Thanks for all your help.
I just ran into this too and was confounded until I found this thread. Renaming bbb-uEnv.txt to uEnv.txt fixed it for me also.
It has been a few months since I used setup_sdcard.sh, and I noticed that the parameter I used to pass ‘–uboot bone’ is now replaced by ‘-dtb beaglebone’. Could that switch have introduced the bug?
