Return Receipt
Your Re: [beagleboard] USB Problems
document:
was tdang@raytheon.com
received
by:
at: 11/24/2009 11:30:39
Well, I had some problems with the power supply that goes to the hub.
My USB devices are working. Thank you for the help.
Thanks for the replies,
I figured that USB on C2 revision board has an issue regarding
noise... Ive encountered random resets.. I shall post an update if i
find a solution.
Yes it does. This is old news. There is a possible fix for it. Yiu can search the archives for the fix.
