Hi, I’m in need of some help.
I want to attach my Beaglebone to the internet using a 3G USB modem (e.g. Vodafone K3770).
I have the latest Ubuntu distro and Linux kernel.
I can see three GSM modems ttyUSB0-3 (using dmesg).
When I try to install wvdial it says that it is not available?
What’s odd… If your running the “latest” it’s already installed…
https://github.com/RobertCNelson/omap-image-builder/blob/master/build_image.sh#L167
Other posts seem to use ppp but are not specific to ubuntu.
Can someone tell me the steps I need to take to get on line?
I have tried to re-build the kernel, just in case but I am stopped.
Can someone tell me what I'm doing wrong?
I went to: http://elinux.org/BeagleBoardUbuntu
Advanced Users only: BeagleBone Kernel v3.8.x source, used in these demo
images: https://github.com/RobertCNelson/linux-dev/tree/am33x-v3.8
git clone git://github.com/RobertCNelson/linux-dev.git
cd linux-dev
git checkout origin/am33x-v3.8 -b tmp
./build_kernel.sh
Everything was OK till I tried to build the kernel.
It asks me for dependencies one of these: ia32-libs will not install! as it
need ia32-libs-multiarch
But this is not installable (or so it says)!!
Okay so obviously, your not running the exact same system as me
(Debian Wheezy amd64), want to provide a few details, otherwise you
haven't provided any details on your host system for us to help you..
aka: lsb_release -cs etc..
Please help, I'm pulling my hair out.
Really after two days? Take a breath, otherwise your just going to burn out..
Does this allow the ia32-libs to be installed on your system..
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install ia32-libs
btw, what does:
dpkg --version
show..
Okay, so depending on how you install wheezy/quanta/raring,
dpkg --print-foreign-architectures is not always enabled to be i386...
So now i check that:
https://github.com/RobertCNelson/linux-dev/blob/am33x-v3.8/tools/host_det.sh#L150
and request that you enable it...
