I would like to use the MMC 8-bit bus in the expansion connector to pipe in data from an FPGA. If I wrote a kernel driver to read in data on the MMC bus and DMA it to RAM, what would limit the maximum clock rate at which I could read the data on this bus? The FPGA is good to 250MHz.
I am just reading data on the MMC, no need for transmitting.
There is a max clock rate on the MMC interface. Likely in the area of
50 MHz. What kind of data are you trying to read from the FPGA?
> pipe in
> MMC
> I
Video.
I've moved data via SPI from an FPGA. You can clock that at 48 MHz also.
pipe in
MMC
I
Video.
I’ve moved data via SPI from an FPGA. You can clock that at 48 MHz also.
If you're looking to do general data transfer between the FPGA and
OMAP3 in a memory mapped fashion (like NOR flash would), the GPMC is
your best bet. You can configure it in various different forms
(synchronous, asynchronous, chip selects, burst capabilities, custom
timings) and it appears as a nice, well behaved memory mapped device
to which you can access from user-space. In terms of bandwidth, you
can achieve up to 180Mhz data clock, with a 16-bit word interface.
Accounting for transactional setup overhead (and assuming bursting),
you can reach potentially up to 300Mbytes/second of raw speed over
that interface. Most likely won't hit this speed due to DDR
limitations, but i did measure on the scope the effective clock period
on the OMAP3 EVM.
If you're doing application specific transfers, like video data
transfers, sound data, etc, your best bet is to use the bandwidth
dedicated peripherals like the video front end of the I2S blocks. The
former has an effective bandwidth of up to 130MBytes/second. This also
supports standard video protocols like BT.656, or parallel YCbCr
transfer using hsync, vsync, etc.
