[beagleboard] Which repository / branch / tag for 2.6.32 Angstrom build?
I'd like to build the 2.6.32 Angstrom that has recently appeared on
http://www.angstrom-distribution.org/demo/beagleboard
I'm having difficulty finding it in the repository, but I'm new to git
so I'm not sure whether this is because it isn't there or because I
can't use the git commands successfully.
I've cloned a repository from
git://git.openembedded.org/openembedded.git openembedded
This contains two branches,
org.openembedded.dev
stable/2009
(although visiting http://cgit.openembedded.org/cgit.cgi/openembedded/
there are far more branches listed, so I don't know why I can't see
those)
So far I've built the head of the stable/2009 branch, and that created
2.6.29r46 output.
How could I have known that branch is associated with that output
version before building it? The command git-tag doesn't list anything
that looks like a useful identifier.
I've tried to find the SHA1 of the 2.6.32 release that's incorporated
in the filenames (uImage-2.6.32-
r70+gitr7b8926aa626991fa087b00f6bbc1fb6b0e8269b0-
beagleboard.bin)without success.
Anyone know where it is, or can show me the correct method of finding
it?
Peter
I just did:
git checkout org.openembedded.dev
to switch to the development version.
Then you can build for example console image as before:
bitbake console-image
HTH,
Andrey.
The 2.6.32 uImage is created from the org.openembedded.dev branch. We recommend using http://gitorious.org/angstrom/angstrom-setup-scripts to build from there. The git revision in the uImage is from the TI PSP git tree. If you want to build it stand alone, http://gitorious.org/angstrom/angstrom-linux/commits/beagleboardXM will be the closest to the angstrom build, http://gitorious.org/beagleboard-validation/linux/commits/beagleboardXM might lag a few days behind.
regards,
Koen
