Hello All
After a long ‘fight’ I was able to figure out that the config files for the Angstrom package manager are looking into a wrong URL.
The wrong Angstrom images are the Cloud9 ones (and the ‘demo’ as well as):
Angstrom-Cloud9-IDE-eglibc-ipk-v2011.11-core-beagleboard-2011.11.21.img.gz
Angstrom-Cloud9-IDE-eglibc-ipk-v2011.11-core-beagleboard.rootfs.tar.bz2
The conf files in ‘/etc/opkg’ are set to: - src/gz base http://feeds.angstrom-distribution.org/feeds/core/ipk/eglibc/armv7a/base - but there is no ‘armv7a’ under ‘/core/ipk/eglibc’, so it comes with a 404 error
I have downloaded and compared the conf files in all images and my guess is that instead of ‘core’ it should be ‘v2012.05’ - I’ve change all my conf files and voila. (conf files in ‘/etc/opkg’).
It would be good if someone from the support team could confirm that that is the correct repository for Cloud9-xM, but after comparing all possibilities I guessed that to be the one.
So to fix, and start using your Beagleboard-xM using the Cloud9 image you need to go to ‘/etc/opkg’ and all the files (except arch.conf) and replace ‘core’ with ‘v2012.05’ - and then ‘opkg update’ will work, hopefully, and you’ll be able to upgrade the packages, etc, etc
PS I tried to find a way to feedback the Angstrom team but I was unsuccessful, id=f someone knows how to contact them please tell me and I’ll do it.
Best,
Joe Rosa
