BeagleBoard xM && Angstrom && Ethernet port problem
Hi all,
I just recived a BeagleBoard xM and I installed succesfully Angstrom
from http://www.angstrom-distribution.org/narcissus/ .
All works fine but I can't use the embedded ethernet port in the
board. It seems that Angstrom hasn't the required driver.
Can you help me?
Thanks.
What do you mean with "Angstrom hasn't the required driver."? It works fine over here.
I mean that the ethernet port isn't recognized automatically when the
board start.
While I have an usb-ethernet converter that is recognized when I plug
it in the usb port of the BeagleBoard.
Sorry, I found the problem.
Usb-Ethernet converter is recognized as eth0
while the on-board ethernet port is recognized as usb0 ...
