I want Angstrom demo image installed on my to draw the X screen on S-
Video output by default. I figured it can be done by doing a "setenv
defaultdisplay tv" on the boot prompt. However as the xM board does
not have an onboard flash memory I guess I have to generate a boot.scr
file to make it permament. Here is the problem: Angstrom demo image
does not include boot.cmd or boot.scr file. So I guess it is just
using the default from u-boot.
I tried to get it working by putting this in boot.cmd:
setenv defaultdisplay tv
boot
and then making boot.scr with the command:
mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n 'Angstrom/
2.6.32/beagleboard' -d boot.cmd boot.scr
However with this boot.scr image beagleboard does not boot up. Any
help appreciated.
Here is the boot log:
Texas Instruments X-Loader 1.4.4ss (Feb 20 2011 - 20:16:03)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03 (Feb 20 2011 - 20:15:58)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you'll see a
harmless I2C error.
No EEPROM on expansion board
Beagle xM Rev A
Die ID #491e00011ff00000015739eb09002016
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
415 bytes read
Running bootscript from mmc ...
## Executing script at 80200000
mmc1 is available
reading uImage
3195484 bytes read
reading uInitrd
** Unable to read "uInitrd" from mmc 0:1 **
## Booting kernel from Legacy Image at 80300000 ...
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3195420 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Wrong Ramdisk Image Format
Ramdisk image is corrupt or invalid
mmc1 is available
reading uImage
3195484 bytes read
reading uInitrd
