I wanted to reactive my old beagleboard-xm. So I went ahead and tried
installing the lastest Ubuntu from [1]. Unfortunately after the
installation the board hangs in a bootloop. I then tried to install
Archlinux from [2] with the same effect. After that I tried installing
Ubuntu 12.04 which worked. But after doing a release upgrade to Ubuntu
14.04 the bootloop reappeared.
This is what I get on the serial console:
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 9eb50000, end 9ef27c8f ... OK
Using Device Tree in place at 88000000, end 88012696
Starting kernel ...
[ 0.000610] WARNING: Your 'console=ttyO2' has been replaced by 'ttyS2'
[ 0.000640] This ensures that you still see kernel messages. Please
[ 0.000640] update your kernel commandline.
[ 0.840972] platform 48058000.ssi-controller: Cannot lookup hwmod 'ssi'
[ 0.844390] of_amba_device_create(): amba_device_add() failed (-19) for /etb@5401b000
[ 0.844543] of_amba_device_create(): amba_device_add() failed (-19) for /etm@54010000
[ 2.899475] Error: Driver 'tfp410' is already registered, aborting...
[ 3.022705] ehci-omap 48064800.ehci: Can't get PHY device for port 1: -517
[ 3.122650] omap2_set_init_voltage: unable to find boot up OPP for vdd_mpu_iva
[ 3.129913] omap2_set_init_voltage: unable to set vdd_mpu_iva
[ 3.136108] omap2_set_init_voltage: unable to find boot up OPP for vdd_core
[ 3.143188] omap2_set_init_voltage: unable to set vdd_core
U-Boot SPL 2015.01-00011-g2efed9f (Jan 12 2015 - 17:15:10)
SPL: Please implement spl_start_uboot() for your board
SPL: Direct Linux boot not active!
reading u-boot.img
reading u-boot.img
U-Boot 2015.01-00011-g2efed9f (Jan 12 2015 - 17:15:10), Build: jenkins-github_Bootloader-Builder-90
OMAP3630/3730-GP ES1.1, CPU-OPP2, L3-200MHz, Max CPU Clock 1 Ghz
I2C: ready
DRAM: 512 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Beagle xM Rev A/B
No EEPROM on expansion board
Die ID #59da00011ff00000015739eb0c019006
Net: usb_ether
Error: usb_ether address not set.
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Checking for: /uEnv.txt ...
Checking for: /boot/uEnv.txt ...
115 bytes read in 33 ms (2.9 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-3.19.0-armv7-x3 ...
5185800 bytes read in 355 ms (13.9 MiB/s)
loading /boot/dtbs/3.19.0-armv7-x3/omap3-beagle-xm-ab.dtb ...
63127 bytes read in 102 ms (603.5 KiB/s)
loading /boot/initrd.img-3.19.0-armv7-x3 ...
4029583 bytes read in 276 ms (13.9 MiB/s)
debug: [console=ttyO2,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc quiet] ...
debug: [bootz 0x82000000 0x88080000:3d7c8f 0x88000000] ...
Kernel image @ 0x82000000 [ 0x000000 - 0x4f2108 ]
Any ideas?
[1] http://elinux.org/BeagleBoardUbuntu#Beagle.2FBeagle_xM
[2] http://archlinuxarm.org/platforms/armv7/ti/beagleboard-xm
