The beagleboard xM is able to boot properly with the image that comes with the beagle (micro sd card)
However, after building a custom configuration on narcissus and trying to boot, it fails to boot i.e. nothing happens after the message
“Uncompressing Linux…”
Please note that I am powering the beagle with a 5V/2A power supply & nothing connected to USB ports on beagle.
When I connect monitor & try to boot, I see the Angstrom splash screen & the status bar updating. After around 60 %, the image vanishes and all I see is a blank screen.
The D6 & D7 LEDs blink in some non-periodic fashion.
Would really appreciate if someone can help me debug it further.
This is what I get on the gtkterm after I powerON the beagle xM:
Texas Instruments X-Loader 1.4.4ss (Jan 29 2011 - 10:54:03)
Beagle xM Rev A
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.03 (Jan 24 2011 - 17:28:53)
OMAP3630/3730-GP ES2.0, CPU-OPP2, L3-165MHz,
I2C: ready
DRAM: 512 MB
NAND: 0 MiB
*** Warning - bad CRC or NAND, using default environment
In: serial
Out: serial
Err: serial
Probing for expansion boards, if none are connected you’ll see a harmless I2C error.
No EEPROM on expansion board
Beagle xM Rev A
Die ID #6c5600011ff00000015739eb0800900f
mmc1 is available
The user button is currently NOT pressed.
reading boot.scr
** Unable to read “boot.scr” from mmc 1:1 **
reading uImage
3195988 bytes read
Booting from mmc …
Booting kernel from Legacy Image at 80200000 …
Image Name: Angstrom/2.6.32/beagleboard
Data Size: 3195924 Bytes = 3 MB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Loading Kernel Image … OK
OK
Starting kernel …
Tushar
